false report in webfrontend --> "zabbix server to running"
  • kaalaus
    • Jun 2013
    Hello!
    I get the following message in zabbix webfrontend:
    "zabbix server is not running. the information displayed may not be current"
    I have done some checks (google for it too ;-) ...) but find no way to fix this issue.
    Here are some technical information regarding my zabbix Installation:
    Centos 6.5
    SELinux = disabled
    iptables = disabled
    zabbix Version = 2.2.4
    - webfrontend is running
    - I can see actual data under "Monitoring/latest data"
    - the command "pgrep -l zabbix_server" shows 39 runnig processes
    Here the Logfileentrys I can see being zabbix startup
    5108:20140627:110220.465 Starting Zabbix Server. Zabbix 2.2.4 (revision 46772).
    5108:20140627:110220.465 ****** Enabled features ******
    5108:20140627:110220.465 SNMP monitoring: YES
    5108:20140627:110220.465 IPMI monitoring: YES
    5108:20140627:110220.465 WEB monitoring: YES
    5108:20140627:110220.465 VMware monitoring: YES
    5108:20140627:110220.465 Jabber notifications: NO
    5108:20140627:110220.465 Ez Texting notifications: YES
    5108:20140627:110220.466 ODBC: NO
    5108:20140627:110220.466 SSH2 support: YES
    5108:20140627:110220.466 IPv6 support: NO
    5108:20140627:110220.466 ******************************
    5108:20140627:110220.466 using configuration file: /usr/local/etc/zabbix_server.conf
    5108:20140627:110220.470 current database version (mandatory/optional): 02020000/02020001
    5108:20140627:110220.470 required mandatory version: 02020000
    5112:20140627:110220.555 server #2 started [db watchdog #1]
    5111:20140627:110220.562 server #1 started [configuration syncer #1]
    5119:20140627:110220.564 server #9 started [trapper #1]
    5120:20140627:110220.565 server #10 started [trapper #2]
    5121:20140627:110220.565 server #11 started [trapper #3]
    5122:20140627:110220.565 server #12 started [trapper #4]
    5123:20140627:110220.568 server #13 started [trapper #5]
    5124:20140627:110220.569 server #14 started [trapper #6]
    5133:20140627:110220.584 server #16 started [trapper #8]
    5134:20140627:110220.585 server #17 started [trapper #9]
    5135:20140627:110220.585 server #18 started [trapper #10]
    5136:20140627:110220.585 server #19 started [trapper #11]
    5132:20140627:110220.586 server #15 started [trapper #7]
    5137:20140627:110220.590 server #20 started [trapper #12]
    5138:20140627:110220.591 server #21 started [trapper #13]
    5139:20140627:110220.591 server #22 started [trapper #14]
    5140:20140627:110220.591 server #23 started [trapper #15]
    5141:20140627:110220.592 server #24 started [icmp pinger #1]
    5142:20140627:110220.595 server #25 started [alerter #1]
    5143:20140627:110220.596 server #26 started [housekeeper #1]
    5143:20140627:110220.596 executing housekeeper
    5144:20140627:110220.596 server #27 started [timer #1]
    5159:20140627:110220.612 server #30 started [history syncer #1]
    5160:20140627:110220.613 server #31 started [history syncer #2]
    5161:20140627:110220.613 server #32 started [history syncer #3]
    5162:20140627:110220.615 server #33 started [history syncer #4]
    5163:20140627:110220.618 server #34 started [escalator #1]
    5164:20140627:110220.621 server #35 started [proxy poller #1]
    5157:20140627:110220.622 server #28 started [http poller #1]
    5108:20140627:110220.625 server #0 started [main process]
    5173:20140627:110220.635 server #37 started [vmware collector #1]
    5174:20140627:110220.635 server #38 started [vmware collector #2]
    5172:20140627:110220.642 server #36 started [self-monitoring #1]
    5143:20140627:110220.655 housekeeper [deleted 0 hist/trends, 0 items, 0 events, 0 sessions, 0 alarms, 0 audit items in 0.047709 sec, idle 1 hour(s)]
    5118:20140627:110220.855 server #8 started [unreachable poller #1]
    5113:20140627:110220.856 server #3 started [poller #1]
    5114:20140627:110220.858 server #4 started [poller #2]
    5117:20140627:110220.859 server #7 started [poller #5]
    5116:20140627:110220.859 server #6 started [poller #4]
    5115:20140627:110220.860 server #5 started [poller #3]
    5158:20140627:110220.867 server #29 started [discoverer #1]
    Did anybody get this error too and know how to fix it?
  • gabriel.wagner
    • Jun 2014
    Check the file /etc/hosts
    127.0.0.1 localhost
    • kaalaus
      • Jun 2013
      127.0.0.1 localhost
      Thank you very much for the good tip.
      Add a line for my lokal IP to /etc/hosts and everything works fine.
