"Login name or password is incorrect" after installing zabbix proxy (2.2.3)
  • FreeNuts
    • Jun 2014
    I tried to install zabbix proxy on CentOS 6.5.
    Zabbix version is 2.2.3
    I followed this procedure:
    Arrived at Step 8 of the installation frontend, I try to connect as shown with Username and password : Admin
    zabbix
    thank you
  • ingus.vilnis
    • Mar 2014
    • 908
    Please check the link you posted to documentation. It is broken somehow. But I suppose you were following this manual: (https://www.zabbix.com/documentation...lation/install)
    Why are you installing Zabbix from sources when there are packages available? It will be mush easier for you to maintain and update your system afterwards if you use packages.
    And now the main thing. You told that you are installing Proxy. There is no frontend needed on Zabbix proxy. You have to configure only zabbix_proxy.conf on your Proxy system, everything else is configured on main Zabbix server frontend.
    Best Regards,
    Ingus
    • FreeNuts
      • Jun 2014
      Thank you, I'll go back to read the documentation, I need apparently
