First I would like to thank the Zabbix crew for this fine product. We're in the midst of migrating our departmental monitoring (80 hosts) from Nagios to Zabbix 1.1a5. I just started rolling it out onto our Windows servers and hit a bit of a snag. While the Zabbix 1.1 agent worked great on our XP host, both the Zabbix 1.0 and 1.1a5 agents bomb out on our Windows 2000 backup server.
This is what I get in the log file with DebugLevel=4:
I suspect that there may not be some service running on the machine that may be required for Zabbix to acquire it's performance information. Here are the normal 'microsoft' services that are currently running, am I missing any that may be required?
Let me know if there is anything I can do to help figure out the problem. Thanks!
[16-Feb-2005 13:34:41] Log file opened
[16-Feb-2005 13:35:24] Unable to add performance counter "\UnknownPerformanceCounter(_Total)\UnknownPerform anceCounter" to query: The specified object is not found on the system.
Background Intelligent Transfer Service COM+ Event System Disk Management Service Distributed Transaction Coordinator DNS Client Event Log Microsoft Console Manager Net Logon Network Connections Plug and Play Print Spooler Protected Storage Remote Procedure Call (RPC) Remote Procedure Call (RPC) Locator Remote Registry Service RunAs Service SavRoam Security Accounts Manager Server System Event Notification Task Scheduler TCP/IP NetBIOS Helper Service Windows Management Instrumentation Windows Management Instrumentation Driver Extensions Windows Time Workstation
