IPMI issues after upgrade to 2.2.4
  • jbecker
    • Jul 2014
    With version 2.2.4 zabbix changed the IPMI reading (ZBX-8188) of sensor data.
    Some Dell PowerEdge iDRAC implementations (like oder PowerEdge R815) however did not support this.
    While the sdr Data from such sensors are ok, the "sensor" functions returning sensor not present.
    You can check this with ipmitool IP:
    ipmitool -H A.B.C.D -U user -P secret -L USER -I lanplus sensor get "CPU 1 Temp" shows:
    Locating sensor record...
    Sensor ID              : CPU 1 Temp (0x1)
     Entity ID             : 3.1
     Sensor Type (Analog)  : Temperature
     Sensor Reading        :  Unable to read sensor: Device Not Present
     Event Status          : Event Messages Disabled
     Assertion Events      :
     Event Enable          : Event Messages Disabled
     Assertions Enabled    :
    ipmitool -H A.B.C.D -U user -P secret -L USER -I lanplus sdr get "CPU 1 Temp" shows:
     Entity ID             : 3.1 (Processor)
     Sensor Reading        : 46 (+/- 1) degrees C
     Status                : ok
     Upper critical        : 85.000
     Upper non-critical    : 80.000
     Positive Hysteresis   : 1.000
     Negative Hysteresis   : 1.000
     Minimum sensor range  : Unspecified
     Maximum sensor range  : Unspecified
     Event Message Control : Per-threshold
     Readable Thresholds   : unc ucr
     Settable Thresholds   :
     Threshold Read Mask   : unc ucr
     Assertion Events      :
    The values from the sdr readings are fine. After the upgrade however zabbix declared these types of sensors as "Not Supported".
    I wounder if it is possible to implement an option in zabbix to control if the ipmi_poller is getting its data from "sensor" oder "sdr".
    Last edited by jbecker; 02-07-2014, 16:16. Reason: for reasons of clarity and comprehensibility
