I am currently deploying Zabbix into our environment and am having quite a bit of trouble trying to get our Zabbix-Proxy and Zabbix-Server to communicate properly.
The scenario here is that the Proxy is on our on-prem environment and is talking to the Zabbix-Server which is our Azure cloud. In between the two is a NAT. They sort of communicate, but not really.
Both Proxy and Server are on version 4.0.8
The logs on the Proxy show:
cannot send proxy data to server at "<server_IP>": ZBX_TCP_READ() failed: [104] Connection reset by peer
The logs on the Server show:
failed to accept an incoming connection: connection rejected, getpeername() failed: [107] Transport endpoint is not connected
I know that this will be something I've missed due to the NAT that's sitting in between them, but I'm at a bit of a loss. I've tried playing around with the source IP address settings in the conf files but that doesn't appear to make any difference.
Any help would be greatly appreciated :-)
Cheers
failed to accept an incoming connection: from <NAT_interface_ip>: reading first byte from connection failed: [104] Connection reset by peer
To get the Proxy to be seen by the Server at all, I have to use the NAT interface that the Proxy appears to be coming from as the IP address of the Proxy in the Proxy config on the Server. I know that this will be something I've missed due to the NAT that's sitting in between them, but I'm at a bit of a loss. I've tried playing around with the source IP address settings in the conf files but that doesn't appear to make any difference.
Cheers
