silent death.
  • konsul
    • Aug 2006
    silent death.
    hello everyone. i have installed zabbix 1.1.1 on sparc-solaris9 host. mysql 5.0.21, php 4.4.2, netsnmp 5.2.0 already installed. compilation and agentrun was no problem. webintterface working fine, but i cant understand why zabbix_server don't wont to run. it starting and just quit like its all right. log in debug mode contain following records in tail:
    022750:20060807:151842 7. PID=[22758]
    022750:20060807:151842 8. PID=[22759]
    022750:20060807:151842 9. PID=[22760]
    022750:20060807:151842 ZABBIX server is up.
    022758:20060807:151842 In child_main()
    022751:20060807:151842 Executing query:select a.alertid,a.mediatypeid,a.sendto,a.subject,a.messa ge,a.status,a.retries,mt.mediatypeid,mt.type,mt.de scription,mt.smtp_server,mt.smtp_helo,mt.smtp_emai l,mt.exec_path,a.delay,mt.gsm_modem from alerts a,media_type mt where a.status=0 and a.retries<3 and (a.repeats<a.maxrepeats or a.maxrepeats=0) and a.nextcheck<=1154949522 and a.mediatypeid=mt.mediatypeid order by a.clock
    022752:20060807:151842 Executing query:select distinct i.itemid,i.key_,h.host,h.port,i.delay,i.descriptio n,i.nextcheck,i.type,i.snmp_community,i.snmp_oid,h .useip,h.ip,i.history,i.lastvalue,i.prevvalue,i.ho stid,h.status,i.value_type,h.errors_from,i.snmp_po rt,i.delta,i.prevorgvalue,i.lastclock,i.units,i.mu ltiplier,i.snmpv3_securityname,i.snmpv3_securityle vel,i.snmpv3_authpassphrase,i.snmpv3_privpassphras e,i.formula,h.available,i.status,i.trapper_hosts,i .logtimefmt,i.valuemapid from hosts h, items i, functions f where h.hostid=i.hostid and h.status=0 and i.status=0 and f.function in ('nodata','date','dayofweek','time','now') and i.itemid=f.itemid
    022756:20060807:151842 In child_main()
    022756:20060807:151842 server #6 started [Trapper]
    022756:20060807:151842 Before DBconnect()
    022756:20060807:151842 After DBconnect()
    022756:20060807:151842 Before accept()
    022760:20060807:151842 In child_main()
    022760:20060807:151842 server #10 started [Trapper]
    022760:20060807:151842 Before DBconnect()
    022753:20060807:151842 In create_host_file()
    022753:20060807:151842 Executing query:select distinct h.ip from hosts h,items i where i.hostid=h.hostid and (h.status=0 or (h.status=0 and h.available=2 and h.disable_until<=1154949522)) and (i.key_='icmpping' or i.key_='icmppingsec') and i.type=3 and i.status=0 and h.useip=1
    022757:20060807:151842 In child_main()
    022757:20060807:151842 server #7 started [Trapper]
    022757:20060807:151842 Before DBconnect()
    022758:20060807:151842 server #8 started [Trapper]
    022758:20060807:151842 Before DBconnect()
    022753:20060807:151842 Executing query:select distinct h.host from hosts h,items i where i.hostid=h.hostid and (h.status=0 or (h.status=0 and h.available=2 and h.disable_until<=1154949522)) and (i.key_='icmpping' or i.key_='icmppingsec') and i.type=3 and i.status=0 and h.useip=0
    022753:20060807:151842 In do_ping()
    022757:20060807:151842 After DBconnect()
    022757:20060807:151842 Before accept()
    022758:20060807:151842 After DBconnect()
    022758:20060807:151842 Before accept()
    022759:20060807:151842 In child_main()
    022759:20060807:151842 server #9 started [Trapper]
    022759:20060807:151842 Before DBconnect()
    022750:20060807:151842 In housekeeping_process_log()
    022750:20060807:151842 Executing query:select housekeeperid, tablename, field, value from housekeeper order by tablename
    022760:20060807:151842 After DBconnect()
    022760:20060807:151842 Before accept()
    022750:20060807:151842 In housekeeping_alarms(1154949522)
    022750:20060807:151842 Executing query:select alarm_history from config
    022750:20060807:151842 Executing query:select alarmid from alarms where clock<1123413522
    022750:20060807:151842 In housekeeping_alerts(1154949522)
    022750:20060807:151842 Executing query:select alert_history from config
    022750:20060807:151842 Executing query:delete from alerts where clock<1123413522
    022759:20060807:151842 After DBconnect()
    022759:20060807:151842 Before accept()
    022750:20060807:151842 Deleted [0] records from table [alerts]
    022750:20060807:151842 In housekeeping_sessions(1154949522)
    022750:20060807:151842 Executing query:delete from sessions where lastaccess<1154863122
    022750:20060807:151842 Deleted [0] records from table [sessions]
    022750:20060807:151842 Sleeping for 1 hours
    022750:20060807:151842 One server process died. Shutting down...
    022750:20060807:151842 0. Killing PID=[22751]
    022750:20060807:151842 1. Killing PID=[22752]
    022751:20060807:151842 Server [1]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    022750:20060807:151842 2. Killing PID=[22753]
    022752:20060807:151842 Server [2]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    022750:20060807:151842 3. Killing PID=[22754]
    022753:20060807:151842 Server [3]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    022750:20060807:151842 4. Killing PID=[22755]
    022750:20060807:151842 5. Killing PID=[22756]
    022750:20060807:151842 6. Killing PID=[22757]
    022756:20060807:151842 Server [6]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    022750:20060807:151842 7. Killing PID=[22758]
    022757:20060807:151842 Server [7]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    022750:20060807:151842 8. Killing PID=[22759]
    022758:20060807:151842 Server [8]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    022759:20060807:151842 Server [9]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    022750:20060807:151842 9. Killing PID=[22760]
    022760:20060807:151842 Server [10]. Got QUIT or INT or TERM or PIPE signal. Exiting...
    022750:20060807:151842 ZABBIX server is down.
    one process die (?) without any reason, and after that all other process killed by main and it quit. truss show this:
    23098: open("/opt/csw/etc/snmp/snmp.conf", O_RDONLY) = 0
    23098: ioctl(0, TCGETA, 0xFFBFE25C) Err#25 ENOTTY
    23098: fstat64(0, 0xFFBFE2D0) = 0
    23098: fstat64(0, 0xFFBFE178) = 0
    23098: read(0, 0x001F392C, 8192) = 53
    23098: \n d e f a u l t P o r t 1 9 1\n d e f V e r s i o n v 2 c\n
    23098: d e f C o m m u n i t y p u b l i c\n\n
    23098: read(0, 0x001F392C, 8192) = 0
    23098: llseek(0, 0, SEEK_CUR) = 53
    23098: close(0) = 0
    23098: open("//.snmp/snmp.conf", O_RDONLY) Err#2 ENOENT
    ....many other places
    23098: open("/opt/csw/var/net-snmp/zabbix_server.conf", O_RDONLY) Err#2 ENOENT
    23098: open("/opt/csw/var/net-snmp/zabbix_server.local.conf", O_RDONLY) Err#2 ENOENT
    23098: times(0xFFBFF1D8) = 172205057
    23098: Incurred fault #1, FLTILL %pc = 0x002535E0
    23098: siginfo: SIGILL ILL_ILLOPC addr=0x002535E0
    23098: Received signal #4, SIGILL [default]
    23090: Received signal #18, SIGCLD, in sigsuspend() [caught]
    23090: siginfo: SIGCLD CLD_KILLED pid=23098 status=0x0004
    yeah, it look for specific option in snmp.conf but trying not only snmp.conf, but zabbix_server.conf too..? looks like my conf not enough. what it want ?
    (server started with -c pathtoconfig option)
    snmp.conf
    defaultPort 191
    defVersion v2c
    defCommunity public
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It looks very similat to problems with CentOS and some other distributions which have MySQL statically linked with openssl. Search forum. Try to compile without SNMP support.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • konsul
      • Aug 2006
      withous snmp all working normal...
      i continue to investigate problem, and found new issue. please look at new truss cut:
      23098: close(0) = 0
      yeah, it look for specific option in snmp.conf but trying not only snmp.conf, but zabbix_server.conf too..? looks like my snmp.conf not enough. what it want ?
      snmp.conf
      defaultPort 191
      defVersion v2c
      defCommunity public
      • konsul
        • Aug 2006
        solved
        i have recompiled openssl -> mysql -> netsnmp -> zabbix in shared mode. all works fine now.
