No data for log monitoring
  • gcaccia
    • Jul 2014
    I'm a new user to Zabbix. I'm trying to get log monitoring to work with Zabbix 2.0.4. I want to see trends for "ERROR" occurrences in a tomcat app log file. I've created an item for the host of type "Zabbix agent (active)", with a key of "log[/var/tom8080/logs/app,ERROR]", a "type of information" of "Log" and status enabled.
    I've confirmed that the Zabbix agent user has read access to the log file and that "hostname" is properly set in the zabbix_agentd.conf file on the host where the log file resides.
    I have confirmed that there are ERROR instances in the log file and I can send requests that generate new ERROR entries. Despite all this, when I view a graph of the item for the host there is no data. What am I missing?
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello and welcome!
    So far you have done all the troubleshooting steps right.
    Can you verify that the path and file name is correct?
    For a test, could you create another small test file with a simple key and having only values ok and error in the log file?
    log[/var/log/test/testlog.log,^ok$|^error$]
    Can you get any data from this test item?
    Best Regards,
    Ingus
    • gcaccia
      • Jul 2014
      Yes, the path and filename are correct. I created a new testlog.log file with content of "ok" and "error", though I used the same directory as the other log file (not sure if that was important or not). Then, in Zabbix I first created a new template. I then added a new item to that template and configured that item for log monitoring for the test log file. I then added that template to the host where the log file resides. Finally, I went to Monitoring->Latest Data and selected the host from the Group/Host combo boxes in the upper right. I then found my item. It shows "Never" for the "Last Check" column. It shows "-" for the "Last Value" column. For the original item that I set up, it actually shows a date of yesterday for "Last Check", but shows a value of 0 for "Last Value" and shows nothing when I view history.
      • ingus.vilnis
        • Mar 2014
        • 908
        Ok, thank you for info!
        Then please check permissions for the user account under which zabbix_server is running, whether it has access to read the contents of that log file directory.
        Best Regards,
        Ingus
        • gcaccia
          • Jul 2014
          did you really mean zabbix_server or zabbix_agent? I have confirmed that the user account under which zabbix_agent is running has read access to the contents of the log file directory. zabbix server is not running on that host.
          • Wamuyu
            • Jan 2023
            Is there a solution for this? I have run into the same error and I cant seem to find a solution.
