Variables
  • jeroenmgage
    • Jun 2014
    • 15
    Variables
    Maybe I'm using the names and contexts wrong, but I'll try to explain what I mean!
    How can I use values of other monitored items in a trigger?
    Example: We have a custom application that has a custom MIB. I've created a new template, discovery rule, prototypes... everything works as it is supposed to! the thing is: the MIB lists some drivers that the system uses by a number. Then there are the OID's that decribe that number. And there are OID's that check if the driver has an error (by the number). Now I would like to combine those two in a trigger message.
    So, the item that has the id:
    QUINSY-QMOBGATE::dvDriverStatus.{#SNMPINDEX}
    which results in (for example):
    QUINSY-QMOBGATE::dvDriverID."01234567"
    then the item that has the name:
    QUINSY-QMOBGATE::dvDriverName.{#SNMPINDEX}
    that results in (for example):
    QUINSY-QMOBGATE::dvDriverName."01234567" = STRING: "Driver Name"
    the item that checks the error:
    QUINSY-QMOBGATE::dvDriverStatusDelayed."01234567" = INTEGER: generalerror(1)
    I have created a key mgwDriverName[{#SNMPVALUE}]
    and the trigger:
    {Template:mgwDriverStatusDelayed[{#SNMPINDEX}].last(#3)}#0
    And what I would like the name to be:
    Driver in Error {HOST.HOST}:mgwDriverName[{#SNMPINDEX}]
    what I wanted to happen is that, if the driver has an error, it would show:
    Driver in Error Host: Driver Name
    but what it shows is:
    Driver in Error Host:mgwDriverName["01234567"]
    What am I getting/doing wrong?
    Regards,
    Jeroen
  • jeroenmgage
    • Jun 2014
    • 15
    I ended up changing the discovery rule to include the OID's that scan the drivernames. Then I can use the SNMPVALUE and SNMPINDEX.
