Frontend can't connect to oracle backend
  • JoohnyO
    • Jul 2014
    • 25
    Hello everyone!
    Im trying to set-up 2.2.4 Zabbix on oracle backend, 11g, and have some problems with it. Both of them is on one redhat 6 server, selinux and iptables is off.
    My zabbix_server is starting, and successfully connecting to DB, with no errors in log file. When im trying to configure web interface i can't get past "Configure DB connection" stage:
    However, my sqlplus, and isql can connect to db with the same parameters.
    Oracle says that all connections through web-interface is successful too
    zabbix ZABBIXDBUSER zabbix.bell2.ru 07-17-2014 12:23:22 0
    where 0 is return code.
    Sorry for my english.
  • jvalenzani
    • Sep 2010
    • 53
    Did you compile sources with Oracle Support? (--with-oracle option)
    • inhayn
      • Sep 2004
      • 13
      I found the same issue with the version 2.4.4 and i did this:
      (set ORACLE_HOME in /etc/sysconfig/httpd)
      Works great for me. Maybe its works for you too.
      Regards.
