Inventory is empty
Host inventory is disabled by default. You need to populate host inventory manually or automatically (from items) and then they will show up.
Doc: https://www.zabbix.com/documentation...ntory/overview -
thx for the reply!
I got, but istill having an issue.
Look:
This is my "Monitoring\overview" I've set it to show all, check, I have 2 hosts.
Now, my "Inventory\hosts"
Grouped by "all" but it shows only 1 host.
About the "Inventory\overview" I got how it works, but I want to see All host's in inventory, using "overview" I can't see all, I think it's ok besause, with the default settings, all hosts doesn't have all "collums" when I set the "grouping"...
I'd like to have "Inventory\hosts" working fine... showing all hosts.Comment
Monitoring/Overview shows information of ITEMS for a certain GROUP.
Inventory/Overview shows information about HOST that have INVENTORY FIELDS filled and ENABLED.
I did it, but nothing was showing, but now I'm understanding, I need to link "Items" to the "fields".
Thx allComment
