bad XML code on export template?
  • harri
    • Nov 2010
    • 89
    Zabbix 2.2.5 on Debian:
    If I export a template as XML, then it seems that the "triggers" are defined outside of the "templates" block. Sample (using the "Template ICMP Ping" template):
    <?xml version="1.0" encoding="UTF-8"?>
    <zabbix_export>
        <version>2.0</version>
        <date>2014-07-20T05:53:32Z</date>
        <groups>
            <group>
                <name>Templates</name>
            </group>
        </groups>
        <templates>
            <template>
                <template>Template ICMP Ping</template>
                <name>Template ICMP Ping</name>
                <groups>
                    <group>
                    </group>
                </groups>
                <items>
                    <item>
                        <name>ICMP loss</name>
                        <type>3</type>
                    </item>
                    <item>
                    </item>
                </items>
                <discovery_rules/>
                <macros/>
                <templates/>
                <screens/>
            </template>
        </templates>
        <triggers>
            <trigger>
                <expression>{Template ICMP Ping:icmppingloss.min(5m)}&gt;20</expression>
                <name>Ping loss is too high on {HOST.NAME}</name>
            </trigger>
            <trigger>
            </trigger>
        </triggers>
    </zabbix_export>
    This looks weird. Doesn't this break importing this XML code?
    Every helpful comment is highly appreciated.
    Harri
