zabbix 2.2.4 add host failed
  • yiwang
    • Jul 2014
    result:
    Template "Template OS Linux" with item key "agent.hostname" already linked to host.
    192.168.100.50 the zabbix server
    to be add host config:
    Server=192.168.100.50
    Hostname=vp6
    ServerActive=192.168.100.50
    config->host->create
    host:
    hostname: vp6
    groups: linux servers
    then set ip
    templete:
    zabbix agent
    os linux
    all config are above.
    can any one show me where is wrong. thanks
  • aib
    • Jan 2014
    • 1615
    First, you have to use ServerActive only if you will use Zabbix Agent(active) check. Otherwise, you don't need it.
    Then, Template APP Zabbix Agent already linked to Template OS Linux.You can link only OS Linux template to your host description.
    Sincerely yours,
    Aleksey
    • Zabber
      • Jan 2015
      I'm getting the same error:
      ERROR: Cannot update host
      But I have no idea why this error appears. The "Template OS Linux" is not linked to this host.
      I'm sorry but I absolutely don't understand what this sentence means. Can you please explain a little bit more?
