Forti FW Monitor isn't working
  • shukryhunt
    • Jul 2019
    Hi
    Am trying to set up my FortiGate 100E firewall to Zabbix monitoring but is not working. trying with SNMP v2
    Error on Zabbix server as below
    Timeout while connecting to "192.168.1.1:161".
    I have install FortiGate templet also.
    I configure the macros also as below
      • Host macros
      • Inherited and host macros
    • ⇒ Remove
      ⇒ Remove
      Add
    TA
    Hunt
  • Atsushi
    • Aug 2013
    • 2028
    The information you posted may have disappeared, but I do not know how it was set. First, from the server that is running Zabbix server, use snmpget command or snmpwalk command to check whether the value can be obtained from the device using SNMPv2.
