web.page.regexp on Windows 2012 R2 - Unsupported scheme: https.
  • Hy3n4
    • Mar 2017
    I've run into a problem with web.page.regexp monitoring on Windows. I get NOT SUPPORTED with result Unsupported scheme: https.
    Only issue I can thing of is that agent is not compiled with curl ssl support.
    Here is example from actual discovery item.
    "{#SCHEME}": "https",
    "{#SSL}": true,
    "{#SITEPORT}": 443,
    "{#SITEPATH}": "",
    "{#SITEDNS}": "hidden-url.ltd"
    Here is item:
    web.page.regexp[{#SCHEME}://{#SITEDNS}:{#SITEPORT}/{#SITEPATH},,,"(HTTP/1\.1 )([0-9]{3})( .*)",12,"\2"]
    Can anybody help me figure out what is causing this?
    Installed versions:
    Zabbix Server: 4.2.4
    Zabbix Agent: 4.2.4 OpenSSL (from Zabbix download page)
    OS: 6.3.9600 Microsoft Windows Server 2012 R2 Standard x64
  • Hamardaban
    • May 2019
    • 2713
    From https://www.zabbix.com/documentation...s/zabbix_agent :
    5 SSL (HTTPS) is supported only if agent is compiled with cURL support. Otherwise the item will turn unsupported.
    • Hy3n4
      • Mar 2017
      That’s exactly what I thought. But I was unable to find any explicit info how is Windows agent compiled by default.
      • Timkaz
        • Nov 2019
        Hi.
        Where i can get zabbix agent for Windows x64 compiled with cURL support?
        I tried many 4.x (zips and msi: 4.0.14,4.2.3,4.2.4,4.2.8,4.4.0,4.4.1) precompiled versions for windows from https://www.zabbix.com/download_agents , but found no one with support scheme https
        • Hy3n4
          • Mar 2017
          Have the same problem.
          • seanwasere
            • May 2012
            • 12
            For checking https endpoints from windows agents using web.page. keys,
            one option you have is to set up a port 80 -->443 redirect on your endpoint.
            eg, a 301 redirect directive in your endpoints nginx config
            or possibly an iptables prerouting rule ( I havent tested this using a prerouting rule myself)
