Aggregated checks doesn't work with "system.run"
  • willened
    • Jul 2014
    Hi
    I have an item Citrix Connected Users which runs "c:\Program Files\zabbix\citrix\countICAUsers.cmd" this works fine.
    Now I want to sum these the values accross a group. I use the grpsum function to do this.
    grpsum["test_quser","system.run[c:\Program Files\zabbix\citrix\countICAUsers.cmd]",last,0]
    This item immediately went to not suported.
    Thanks, Dennis
  • ingus.vilnis
    • Mar 2014
    • 908
    Hi Dennis,
    I see two things you could check:
    • Does the host group "test_quser" exist? (not a typo or something?)
    • Is the item with key "system.run[c:\Program Files\zabbix\citrix\countICAUsers.cmd]" collecting data properly?
    Best Regards,
    Ingus
    • willened
      • Jul 2014
      Hi Ingus,
      thanks for your reply.
      • yes the group exists an there is no typo
      • yes the item with key "system.run[c:\Program Files\zabbix\citrix\countICAUsers.cmd]" collecting data properly
      Best regards,
      Dennis
      • ingus.vilnis
        • Mar 2014
        • 908
        Dennis,
        Hard to tell then.
        What is the error message you have for this not supported item? (click on the red icon on the column right next to "Not supported")
        Just another guess - have you set the Item Type to "Zabbix aggregate"?
        Best Regards,
        Ingus
        • willened
          • Jul 2014
          Thank you, I checked the item typ and it was set to "Zabbix Agent". Set it to "Zabbix aggregate" now it works!
          Best Dennis
