Zabbix Aggregate cannot find key in host group
  • mcragun
    • Jul 2014
    I have a host group "Linux servers" and I would like to collect the aggregate load on the cpus.
    On one of the servers in the group, I have created an item with the following parameters:
    type: Zabbix aggregate
    key: grpavg["Linux servers","system.cpu.load[,avg1]",last,0]
    Type of Information: Numeric (Float)
    However, when I save it, after several minutes it says "not supported" with error:
    'No items for key "system.cpu.load[,avg1]" in group "Linux servers"
    I've double checked the spelling and names and am a little confused. I know that my hosts within the group are all collecting data. Does anyone have any suggestions of how to debug my setup?
    Thanks,
    Matt
  • jnichols
    • May 2015
    did you figure this out? i'm having the same problem.
    • imoskovko
      • Jan 2015
      i think i am also unable to use aggregate function to figureout number of hosts in group
      grpsum["HostGroup","vfs.file.exist[/etc/hosts]",last,0]
      it returns
      No items for key "vfs.file.exist[/etc/hosts]" in group(s) "HostGroup"
      Can one elaborate or share experience on aggregate function usage.
      • ingus.vilnis
        • Mar 2014
        • 908
        Hi all,
        The reason for this is quite simple.
        On hosts in group(s) "HostGroup" you must have items with exactly the same key as referenced in that aggregate formula "vfs.file.exist[/etc/hosts]" otherwise you will have that error.
        Aggregate items are not collecting values themselves, they just get them from already existing items.
        Also keep in mind that the item key must be 100% match, not a symbol more or less.
        So e.g. "system.cpu.load[,avg1]" must be on hosts and not "system.cpu.load[]" or anything else.
        When doing aggregated checks then they will return the same value for all of the hosts therefore sometimes it might be useful to have a dummy host that contains those aggregate items. Having them on host level just wastes your disk space otherwise.
        Hope this explains a little.
        Best Regards,
        Ingus
        • imoskovko
          • Jan 2015
          Ingus, thank you a lot for comprehensive explanation.
          • Szymon
            • Sep 2023
            what to do when only difference between item key name and agregate key with MACRO is that they have "" between ?
            item key name : keepalived.vip.["10.128.5.10/32"]
            agregate item
            {$KEEPALIVED_CALC_GROUP} = X-Group Cluster lab
            {$KEEPALIVED_CALC_IP} = keepalived.vip.["10.128.5.10/32"]
            grpsum["{$KEEPALIVED_CALC_GROUP}","{$KEEPALIVED_CALC_ IP}" ,sum,last]
            of course I tested lot of variables with "keepalived.vip.["10.128.5.10/32"]"
            and there is still
            No items for key "keepalived.vip.[10.128.5.10/32]" in group(s) "X-Group Cluster lab".
            ["10.128.5.10/32"] vs ["10.128.5.10/32"] or [10.128.5.10/32]
