Problem with UserParameter
  • BartTechne
    • Jan 2019
    • 15
    I have this in my conf file: (agentd)
    ### Option: UserParameter
    # User-defined parameter to monitor. There can be several user-defined parameters.
    # Format: UserParameter=<key>,<shell command>
    # Mandatory: no
    # Default:
    # UserParameter=
    UserParameter=mssql.db.discovery,powershell -NoProfile -ExecutionPolicy Bypass -File "C:\zabbix\scripts\mssql_basename.ps1"
    UserParameter=mssql.version,powershell -NoProfile -ExecutionPolicy Bypass -File "C:\zabbix\scripts\mssql_version.ps1"
    But for some odd reason when I use the Template on my host. I keep getting unsupported item key ?
    When i run the powershells on their own, i get my value back in the normal JSON format.
    Any ideas?
  • ingus.vilnis
    • Mar 2014
    • 908
    Did you restart the agent service after adding the lines in the config?
    Also UnsafeUserParameters must be enabled if you use quotes in your commands.
    • demoss
      • Oct 2018
      • 9
      <never mind, I misread your question>
