Function COUNT
  • mauro
    • Jan 2017
    • 94
    Function COUNT
    Hello.
    Little problem.
    it's probably my problem that I didn't understand what the function does ...
    I need to count how many times a word appears in the last item acquired.
    specifically I have to count how many times "successfully" happens, if it is not equal to two I have to raise the trigger.
    then this is my simple code:
    {HOST07:testRestore.count(#1,successfully)}<>2
    but it does not work.
    the item vaule is this:
    *********** TEST DI RESTORE FILE ********
    *********** DATA TEST: 27.07.2019 6:00:03,18
    Test recupero file: C:\DASHARE\unins000.dat
    Il test e' valido se al termine compare la scritta 'The operation completed successfully.'
    Total time: 00:00:05
    even with the test (under trigger constructor) I always get false.
    I tried in many way... nothing.
  • AvaTTaR
    • Dec 2018
    • 96
    I didn`t get clear what exactly you need..
    If we talk about how many last ten results includes a word "acquired" than it will be count(#10,"acquired")
    about {HOST07:testRestore.count(#1,successfully)}<>2 your misstake is in count of results and better comment strings - {HOST07:testRestore.count(#2,"successfully")}<>2
    • mauro
      • Jan 2017
      • 94
      Thx for reply.
      I need to know how many times appears the word "succesfully" in the last value of the item "testRestore".
      I thought of using the count function, setting as the first parameter #1 but the result il always false .
      In the example shown it is clear that it should be false (there are two "succesfully" and the condition is <> 2) but it is still false even if I put <> 1 or if I change the test value with only one occurrence.
      • mauro
        • Jan 2017
        • 94
        Ok, we bypass the obstacle.
        at this point I could do this:
        {HOST07:testRestore.count (# 1, ^*successfully*succesfully* $)} <> 1
        so it should go and reach the goal.
        but I still can't get it to work.
        ideas?
        • mauro
          • Jan 2017
          • 94
          resolved in this way:
          {HOST07:testRestore.regexp(.*successfully.*success fully.*,#1)}=0
          and now works.
