orabbix error on zabbix 4.2.4
  • orwin.lopes
    • Jun 2019
    I am trying to use orrabix to monitor oracle 12g database on zabbix 4.2.4. While starting the orrabix agent i get the below error :-
    Stopping
    java.lang.Exception: ERROR on main - Connections is empty
    at com.smartmarmot.orabbix.Orabbixmon.run(Orabbixmon. java:101)
    at com.smartmarmot.orabbix.bootstrap.main(bootstrap.j ava:50)
    Telnet to oracle host is ok on port 1521
    Checking the logs :-
    2019-07-29 10:42:11,131 [main] INFO Orabbix - Starting Orabbix Version 1.2.3
    2019-07-29 10:42:11,193 [main] INFO Orabbix - Orabbix started with pid:3292
    2019-07-29 10:42:11,193 [main] INFO Orabbix - PidFile -> ./logs/orabbix.pid
    2019-07-29 10:42:11,196 [main] DEBUG Orabbix - getConnection for database orcl
    2019-07-29 10:42:11,434 [main] DEBUG Orabbix - Note: orcl.MaxActive null
    2019-07-29 10:42:11,435 [main] DEBUG Orabbix - Note: orcl.MaxWait null
    2019-07-29 10:42:11,435 [main] DEBUG Orabbix - Note: orcl.MaxIdle null
    2019-07-29 10:42:11,435 [main] INFO Orabbix - DB Pool created: org.apache.commons.dbcp.datasources.SharedPoolData Source@ea1a8d5
    2019-07-29 10:42:11,435 [main] INFO Orabbix - URL=jdbcracle:thin:@192.168.235.204:1521rcl
    2019-07-29 10:42:11,435 [main] INFO Orabbix - maxPoolSize=10
    2019-07-29 10:42:11,435 [main] INFO Orabbix - maxIdleSize=1
    2019-07-29 10:42:11,435 [main] INFO Orabbix - maxIdleTime=1800000ms
    2019-07-29 10:42:11,435 [main] INFO Orabbix - poolTimeout=100
    2019-07-29 10:42:11,435 [main] INFO Orabbix - timeBetweenEvictionRunsMillis=-1
    2019-07-29 10:42:11,435 [main] INFO Orabbix - numTestsPerEvictionRun=3
    2019-07-29 10:42:11,707 [main] ERROR Orabbix - Error on Configurator for database orcl -->ORA-28040: No matching authentication protocol
    2019-07-29 10:42:11,707 [main] INFO Orabbix - This Database orcl removed
    2019-07-29 10:42:11,708 [main] ERROR Orabbix - ERROR on main - Connections is empty
  • gufrank
    • Aug 2020
    Hi any update?
    I am also connecting to a 19c DB and it generates the same error.
    BBDDA.Url=jdbcracle:thin:@10.11.11.11:1521/BBDDD
    BBDDA.User=system
    BBDDA.Password=XXXXXX
    BBDDA.QueryListFile=/opt/orabbix/conf/templates/XX_query.props
    BBDDA.ExtraQueryListFile=./conf/XXXX_query.props
    BBDDA.MaxActive=10
    BBDDA.MaxWait=100
    BBDDA.MaxIdle=1
    [root@alerts logs]# more orabbix.log
    2020-08-11 11:41:22,908 [main] INFO Orabbix - Starting Orabbix Version 1.2.3 ,Compiled by wxf 2018.12.23
    2020-08-11 11:41:23,023 [main] INFO Orabbix - Orabbix started with pid:26298
    2020-08-11 11:41:23,023 [main] INFO Orabbix - PidFile -> ./logs/orabbix_addd92.pid
    2020-08-11 11:41:23,536 [main] INFO Orabbix - DB Pool created: org.apache.commons.dbcp.datasources.SharedPoolData Source@3cf720d5
    2020-08-11 11:41:23,537 [main] INFO Orabbix - URL=jdbcracle:thin:@10.117.11.10:1521/BBDDD
    2020-08-11 11:41:23,537 [main] INFO Orabbix - maxPoolSize=10
    2020-08-11 11:41:23,537 [main] INFO Orabbix - maxIdleSize=1
    2020-08-11 11:41:23,537 [main] INFO Orabbix - maxIdleTime=1800000ms
    2020-08-11 11:41:23,537 [main] INFO Orabbix - poolTimeout=100
    2020-08-11 11:41:23,537 [main] INFO Orabbix - timeBetweenEvictionRunsMillis=-1
    2020-08-11 11:41:23,537 [main] INFO Orabbix - numTestsPerEvictionRun=3
    2020-08-11 11:41:23,932 [main] ERROR Orabbix - Error on Configurator for database BBDDA -->ORA-28040: No matching authentication protocol
    2020-08-11 11:41:23,932 [main] INFO Orabbix - This Database BBDDA removed
    2020-08-11 11:41:23,933 [main] ERROR Orabbix - ERROR on main - Connections is empty
    [root@alerts logs]#
