Dell Equallogic template showing unknown
  • s_hughes78
    • Jul 2014
    My first post and i was hoping for some help?
    I recently loaded the Dell Equallogic template from the below url
    Join the friendly and open Zabbix community on our forums and social media platforms.
    SNMP is set correctly in the config etc and it was working for short time doing the discovery. Some of the tiggers showed as enabled and some were 'not supported'.
    Then all of a sudden all 190 triggers went into the 'unknown' state.
    Server logs show an abundance of the following error(s)...
    ":eqliscsiVolumeAdminStatus.["330857136.85"]] became not supported: SNMP error: (noSuchName) There is no such variable name in this MIB."
    :volumepercentused.["330857136.94"]] became not supported: Cannot evaluate function [last()]: item [SAN :eqliscsiVolumeStatusAllocatedSpace.["330857136.94"]] not found
    I have had a look on-line and i can't find an answer to this problem.
    Why would it work and then stop?
    Is there limitations to the collection (there are 190 triggers and 443 items)?
    I'm running server 2.2
    Any further info needed, please ask.
  • s_hughes78
    • Jul 2014
    Just some further info if it helps.
    I have dropped the mib files (.txt) into /usr/share/snmp/mibs
    I have created a snmp.conf file in /usr/share/snmp/
    This file has the following string - mibdirs /usr/share/snmp/mibs/
    If i run the following command it works and gives the MIB that the -IR parameter lives in.
    /]# snmptranslate -M /usr/share/snmp/mibs/ -IR dot3StatsIndex
    EtherLike-MIB::dot3StatsIndex
    If i run the same command but change the -IR to an object in one of the Dell MIB's i get the following error...
    /]# snmptranslate -M /usr/share/snmp/mibs/ -IR eqlGroupIsStorageOptimization
    Unknown object identifier: eqlGroupIsStorageOptimization
    Any idea's?
