Zabbix not listening and no mysql connection
  • AdrianSevcenco
    • Aug 2014
    Hi! I m trying to install zabix on a centos 6.5 server
    the problem si that the zabbix_server do no listen
    and cannot create mysql connection...
    but: i can connect by doing mysql -u zabbix zabbix -p and the show tables;
    looks ok
    my settings are:
    [root@monitor zabbix]# grep ^[0-9,A-F,a-f] /etc/zabbix/zabbix_server.conf
    DebugLevel=2
    DBHost=localhost
    DBName=zabbix
    DBUser=zabbix
    DBPassword='PAROLA_SECRETA'
    DBSocket=/var/lib/mysql/mysql.sock
    AlertScriptsPath=/usr/lib/zabbix/alertscripts
    ExternalScripts=/usr/lib/zabbix/externalscripts
    FpingLocation=/usr/sbin/fping
    Fping6Location=/usr/sbin/fping6
    AllowRoot=0
    [root@monitor web]# cat zabbix.conf.php
    <?php
    // Zabbix GUI configuration file
    global $DB;
    $DB['TYPE'] = 'MYSQL';
    $DB['SERVER'] = 'localhost';
    $DB['PORT'] = '3306';
    $DB['DATABASE'] = 'zabbix';
    $DB['USER'] = 'zabbix';
    $DB['PASSWORD'] = 'PAROLA_SECRETA';
    // SCHEMA is relevant only for IBM_DB2 database
    $DB['SCHEMA'] = '';
    $ZBX_SERVER = 'localhost';
    $ZBX_SERVER_PORT = '10051';
    $ZBX_SERVER_NAME = '';
    $IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
    does anyone have any idea why this is not working?
    i found no information in any installation turorial...
    Thanks a lot!!
    Adrian
  • jvalenzani
    • Sep 2010
    • 53
    Check zabbix_server.log for errors.
    • AdrianSevcenco
      • Aug 2014
      yea, well, the error was that it cannot conect to mysql db .. and the reason was because i escaped the password in zabbix_server.conf
      It would be helpful to have in documentation some remarks about the method of reading information from zabbix_server.conf...
      Thanks!
