Possible Bug: Zabbix Server loses Connectivity to Agent on SNMP Monitored Hosts
  • rob9988
    • May 2006
    • 10
    Version:
    Zabbix 1.1 (server and agent)
    Server OS:
    SuSE Enterprise Linux 9 SP3 (9.3)
    Client OS:
    Problem:
    Zabbix server loses all connectivity to Zabbix agent when SNMP monitored items do not respond (i.e. the application which reports status via SNMP is not running).
    Details:
    - Server and agent were working fine with a mix of SNMP and agent items
    - Server was rebooted to implement new changes to monitored app; the app failed to restart, so SNMP data were no longer available
    - Zabbix server could no longer connect to the agent. Message: "Timeout while connecting to [host.ourdomain.com]:nnn" (where nnn=the port number which we use for SNMP monitoring)
    - Telnet to the host on port 10050 worked, and returned a ZBX error
    Workaround:
    Disabling all SNMP items for the monitored host resulted in the Zabbix server being able to immediately establish a connection to the agent and once again start collecting data.
    Anyone else experiencing this bug?
    -Rob
    PS: Here's a link to my response to another post about this problem:
  • dantheman
    • May 2006
    • 209
    I had this with a handful of cisco switches, I had added an SNMP item to monitor the temperature and then 7 of my 9 switches become unreachable and none of the other items were collected, once I deleted the temperature item (none of my switches supported it ) then I was getting the rest of the snmp data again. It's not my only unsupported SNMP item either.. I have others that are not causing problems.
