zabbix's db mysql export and import
  • wilp
    • Oct 2016
    • 28
    Hi!
    I have a question.
    I want to export zabbix's mysql db from one zabbix server (call SRV-A) and import it in enother zabbix server (SRV-B).
    Both SRV-A and SRV-B have same configuration:
    zabbix appliance 4.0
    MySQL Server version: 5.7.26-0ubuntu0.16.04.1 (Ubuntu)
    but SRV-A have production db and SRV-B have empty db.
    on both SRV-A and SRV-B zabbix-server's service is running
    Well.
    Actions on SRV-A:
    I can see size of production mysql db
    appliance@zabbix:~/mysql_db_bkp$ sudo su
    root@zabbix:/home/appliance/mysql_db_bkp# mysql
    Welcome to the MySQL monitor.  Commands end with ; or \g.
    Your MySQL connection id is 6332
    Server version: 5.7.27-0ubuntu0.16.04.1 (Ubuntu)
    Copyright (c) 2000, 2019, Oracle and/or its affiliates. All rights reserved.
    Oracle is a registered trademark of Oracle Corporation and/or its
    affiliates. Other names may be trademarks of their respective
    owners.
    Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
    mysql> SELECT table_schema "databases name", sum(data_length + index_length)/1024/1024  "DВ size in MB" FROM information_schema.TABLES GROUP BY table_schema;
    | databases name     | DВ size in MB  |
    | information_schema |     0.15625000 |
    | mysql              |     2.64630795 |
    | performance_schema |     0.00000000 |
    | sys                |     0.01562500 |
    | zabbix             |  4259.20312500 |
    OK.
    I executed command for export mysql db from mysql server and to archived to gz format.
    sudo mysqldump zabbix --add-drop-table --add-locks --extended-insert --single-transaction --quick -u zabbix -p | gzip > mysql_db_bkp/zbx_db_bkp_20190808.db.gz
    or to do by article
    https://www.zabbix.com/documentation/4.0/manual/appliance
    sudo mysqldump zabbix | bzip2 -9 > dbdump.bz2
    get backup file.
    ls -lah
    -rw-rw-r-- 1 appliance appliance 250M Aug  8 07:19 zbx_db_bkp_20190808.db.gz
    Actions on SRV-B:
    Get file zbx_db_bkp_20190808.db.gz from SRV-A to SRV-B.
    I have to stop zabbix-server's service
    And I executed revers command:
    sudo zcat zbx_db_bkp_20190808.db.gz | mysql zabbix -u zabbix -p
    or to do by article
    bzcat dbdump.bz2 | sudo mysql zabbix
    Well.
    I can see size of mysql db on SRV-B:
    root@zabbix:/home/appliance# mysql
    Your MySQL connection id is 7196
    owners.
    | mysql              |     2.61459637 |
    | sys                |     0.01562500 |
    | zabbix             |  3425.34375000 |
    5 rows in set (0.27 sec)
    mysql> exit
    Bye
    My question:
    Why does mysql db SRV-B less than mysql db SRV-A ?
    Many thanks for your answers!
  • wilp
    • Oct 2016
    • 28
    I mean where disappeared 1Gb of data?
    Is all data exporting wtih this methods?:
    or
    • zux
      • Sep 2018
      • 97
      try optimizing the original tables, see if there is difference after that.
      overall, I would use count(*) to check if all data is transferred.
      • wilp
        • Oct 2016
        • 28
        How can i use count(*) in mysql for zabbix's db?
        Could you show me example please?
        I find this solution:
        mysql
        SELECT SUM(TABLE_ROWS)
            FROM INFORMATION_SCHEMA.TABLES
            WHERE TABLE_SCHEMA = 'zabbix';
        • zux
          • Sep 2018
          • 97
          select count(*) from items;
          select count(*) from hosts;
          This will give you an idea if the amount of hosts and items is the same.
          You can use this on other tables also.
