5269:20140801:161033.196 Starting Zabbix Server. Zabbix 2.2.4 (revision 46772).
5269:20140801:161033.197 ****** Enabled features ******
5269:20140801:161033.197 SNMP monitoring: YES
5269:20140801:161033.197 IPMI monitoring: YES
5269:20140801:161033.197 WEB monitoring: YES
5269:20140801:161033.197 VMware monitoring: YES
5269:20140801:161033.197 Jabber notifications: YES
5269:20140801:161033.197 Ez Texting notifications: YES
5269:20140801:161033.197 ODBC: YES
5269:20140801:161033.197 SSH2 support: YES
5269:20140801:161033.197 IPv6 support: YES
5269:20140801:161033.197 ******************************
5269:20140801:161033.197 using configuration file: /etc/zabbix/zabbix_server.conf
5269:20140801:161033.659 current database version (mandatory/optional): 02020000/02020001
5269:20140801:161033.659 required mandatory version: 02020000
[root@zabbix-server zabbix]# mysql -u zabbix_user
Welcome to the MariaDB monitor. Commands end with ; or \g.
Your MariaDB connection id is 1272
Server version: 10.0.11-MariaDB MariaDB Server
Copyright (c) 2000, 2014, Oracle, SkySQL Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> \s
mysql Ver 15.1 Distrib 10.0.11-MariaDB, for Linux (x86_64) using readline 5.1
Connection id: 1272
Current database:
Current user: zabbix_user@localhost
SSL: Not in use
Current pager: stdout
Using outfile: ''
Using delimiter: ;
Server: MariaDB
Protocol version: 10
Connection: Localhost via UNIX socket
Server characterset: latin1
Db characterset: latin1
Client characterset: utf8
Conn. characterset: utf8
UNIX socket: /var/lib/mysql/mysql.sock
Uptime: 80 days 23 hours 58 min 11 sec
Threads: 1 Questions: 5186 Slow queries: 0 Opens: 109 Flush tables: 1 Open tables: 117 Queries per second avg: 0.000
MariaDB [(none)]>
[root@zabbix-server zabbix]# uname -a
Linux zabbix-server.xxxxxxxx.com 2.6.32-431.17.1.el6.x86_64 #1 SMP Wed May 7 23:32:49 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
The Discovery Rule looks like this:
Type: External check
Key: ifDiscover.rb[{$SNMP_COMMUNITY},{HOST.CONN}]
The ifDiscover.rb script looks like this:
#!/usr/bin/ruby
require 'rubygems'
require 'snmp'
File.open("/usr/lib/zabbix/externalscripts/ifDiscover.log", mode="a") do |f| f.puts ARGV end
unless ARGV.length == 2
$stderr.puts "ex: #{$PROGRAM_NAME} <community> <ipaddress>"
exit
end
community = ARGV[0]
ip = ARGV[1]
puts "{"
puts %("data":[)
ifTable_columns = ["ifIndex", "ifDescr", "ifAlias"]
SNMP::Manager.open(:Host => ip, :Community => community) do |manager|
manager.walk(ifTable_columns) do |row|
if row[2].value.is_a?(String)
ifAlias = row[2].value.gsub('"','')
else
ifAlias = ''
end
puts %({ "{#SNMPINDEX}":"#{row[0].value}", "{#IFDESCR}":"#{row[1].value}", "{#IFALIAS}":"#{ifAlias}" },)
end
end
puts "]"
puts "}"
It generates output that looks like this:
"data":[
{ "{#SNMPINDEX}":"1", "{#IFDESCR}":"GigabitEthernet1/1", "{#IFALIAS}":"26135AccessData VRF->Base" },
{ "{#SNMPINDEX}":"2", "{#IFDESCR}":"GigabitEthernet1/2", "{#IFALIAS}":"26135AccessData Base->VRF" },
{ "{#SNMPINDEX}":"3", "{#IFDESCR}":"GigabitEthernet1/3", "{#IFALIAS}":"12255/42190 - Standard Plumbing VRF->Base" },
{ "{#SNMPINDEX}":"4", "{#IFDESCR}":"GigabitEthernet1/4", "{#IFALIAS}":"12255/42190 - Standard Plumbing Base->VRF" },
{ "{#SNMPINDEX}":"5", "{#IFDESCR}":"GigabitEthernet1/5", "{#IFALIAS}":"30242LarkinMort VRF->Base" },
{ "{#SNMPINDEX}":"6", "{#IFDESCR}":"GigabitEthernet1/6", "{#IFALIAS}":"30242LarkinMort Base->VRF" },
{ "{#SNMPINDEX}":"7", "{#IFDESCR}":"GigabitEthernet1/7", "{#IFALIAS}":"53085 - Ingram Medical VRF->Base" },
{ "{#SNMPINDEX}":"8", "{#IFDESCR}":"GigabitEthernet1/8", "{#IFALIAS}":"53085 - Ingram Medical Base->VRF" },
{ "{#SNMPINDEX}":"9", "{#IFDESCR}":"GigabitEthernet1/9", "{#IFALIAS}":"53085 - Ingram Medical Pharmacies VRF->Base" },
{ "{#SNMPINDEX}":"10", "{#IFDESCR}":"GigabitEthernet1/10", "{#IFALIAS}":"53085 - Ingram Medical Pharmacies Base->VRF" },
My Item Prototype(s) look like this:
Name: Incoming traffic on $1:$2
Type: SNMPv2 agent
Key: ifInOctets[{#IFDESCR},{#IFALIAS}]
SNMP OID: IF-MIB::ifHCInOctets.{#SNMPINDEX}
SNMP community: {$SNMP_COMMUNITY}
Port: <left blank>
Type of information: Numeric (unsigned)
Data type: Decimal
Units: bps
Use customer multiplier: <checked> 8
Store value: Delta (speed per second)
Enabled: <checked>
But the Items never populate. I've had this exact same LLD rule/script/item-prototype running on FreeBSD 9.x/zabbix 2.2.2/Postgres 9.x and it runs just fine. In fact, this was mostly just copy-n-pasted from that setup.
I've verified that the external script is in fact getting ran with the correct parameters.
Can anyone see any problem with this configuration? This is driving me NUTS!
Any help would be appreciated.
Thanks in advance.
Connection id: 1272
Current database:
SSL: Not in use
Using outfile: ''
Using delimiter: ;
Server: MariaDB
MariaDB [(none)]>
#!/usr/bin/ruby
require 'rubygems'
require 'snmp'
exit
end
community = ARGV[0]
ip = ARGV[1]
puts "{"
puts %("data":[)
else
ifAlias = ''
end
end
end
puts "]"
puts "}"
"data":[
Type: SNMPv2 agent
Port: <left blank>
Data type: Decimal
Units: bps
Enabled: <checked>
Thanks in advance.
