i have followed the Zabbix manual for getting SNMP Traps send to the server.
I have installed all programs on my Zabbix Server and I was receiving the test MSG generated by my Server in the CLI.
Everything is working fine.
Now i moved onto a switch.
I added all commands and I see the SNMP traps in my test file however zabbix did not pick up the traps.
When looking into it a little I noticed that I had a proxy monitoring the switch.
I changed the "Monitored by proxy" to (no proxy), so this means that the server is now monitoring that host.
I create a snmp trap event (shut and no shut for a port) and I see the traps in zabbix now. When I change the host to be monitored by a proxy the traps don't show up.
Is it a requirement that the SNMP Traps need to be send to the Zabbix Proxy that is monitoring that host?
Thank you!
Daniel
Thank you!
Daniel
