cannot parse OID
  • spartaxie
    • Aug 2014
    cannot parse OID
    hi , i was import one template for cisco device,but is not working normal,show me not supported,
    error"snmp_parse_oid(): cannot parse OID "IF-MIB::ifDescr",
    and i use snmpwalk and snmptranslate to my linux server ,it is ok.
    so how can i fix it ? help me ,thanks .......
  • evertonco
    • Aug 2014
    • 75
    Try create an single item for a random interface listed by your snmpwalk command output, such "IF-MIB::ifDescr.1001"
    • amalov
      • Oct 2014
      I've imported template ZBX-CISCO-INTERFACES and met the same issue.
      I've modified discovery rule, and replace SNMP OID to IfDescr instead of "IF-MIB::ifDescr.
      It works fine for me.
      Zabbix 2.2.6
