Adding first device
  • gonzo
    • Aug 2019
    Adding first device
    I've successfully built my first Zabbix server using CentOS 7 as the OS with Apache/MySQL. I've also built LibreNMS and I want to compare the two before choosing one.
    I've got a Cisco router (SNMP) live on the network and use Zabbix to run an SNMP walk which worked and then followed these instructions to add the device:
    https://techexpert.tips/zabbix/zabbi...o-switch-snmp/
    I've waited over and hour and nothing has appeared. All I see is a healthy Zabbix server.
    What have I don't wrong?
  • storyteller
    • Oct 2019
    • 23
    Check if your community is the same on Cisco switch and on template. By default the community in zabbix is "public" and is configured by {$SNMP_COMMUNITY} macro from Administration - General - Macros. If you set a custom string as community add this in your template at Macros tab.
    A good starting point is to probe your switch with snmpwalk like brunorici example.
    If snmpwalk command is not installed you can install on Centos 7 with: yum install net-snmp-utils
