Zabbix install fails with Transaction check error
  • rev6
    • Aug 2019
    Hi all-
    I'm trying to install zabbix agent on centos 7. I receive an error:
    Transaction check error:
    file /etc/zabbix/zabbix_agentd.conf from install of zabbix-agent-4.0.11-1.el7.x86_64 conflicts with file from package zabbix40-4.0.6-1.el7.x86_64
    I have tried changing repos, clearing yum cache. No luck. What is strange is that I have several other centos 7 machines (clones of each other) where the install went fine.
    Can I just force the install since it's just the .conf file?
  • Atsushi
    • Aug 2013
    • 2028
    Try removing the zabbix40 package.
    • rev6
      • Aug 2019
      Thanks! That worked. Is it posible to have both installed?
      • Atsushi
        • Aug 2013
        • 2028
        It is impossible to install both. The yum command decided that there would be a problem if both were installed, so it could not be installed. You shouldn't install both, possibly due to feature or file conflicts.
        Be aware that installing the same software from different repositories may cause conflicts and failures with other software as well.
