Zabbix postgres agent Unsupported item key
  • mlrtime
    • Aug 2019
    • 15
    I have a agent and server, both are communicating ok. I have the official postgres template added to the server. I have another host that is connecting fine, however this host is giving me unsupported item key.
    27942:20190820:140303.580 item "hostA:pgsql.bgwriter["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.DB}"]" became not supported: Unsupported item key.
    When I run zabbix_get on the server, everything returns fine
    [root@zabbix ~]# zabbix_get -s hostA -p 10050 -k "pgsql.bgwriter["127.0.0.1","5432","zbx_monitor","postgres"]"
    {"checkpoints_timed":31740,"checkpoints_req":11 4," checkpoint_write_time":880725336,"checkpoint_sync_ time":129344,"buffers_checkpoint":163658883072,"bu ffers_clean":274905767936,"maxwritten_clean":26391 4,"buffers_backend":1046067863552,"buffers_backe nd _fsync":0,"buffers_alloc":48555576836096}
    Also, when the zabbix server log shows unsupported item key, I do not see any requests at all in the agent log, I have it at Loglevel 4. When I run zabbix_get I do see the items in the log:
    zabbix_agentd.log: 13949:20190820:101651.248 Requested [pgsql.bgwriter[127.0.0.1,5432,zbx_monitor,postgres]]
    zabbix_agentd.log: 13949:20190820:101651.248 In zbx_popen() command:' psql -qtAX -h 127.0.0.1 -p 5432 -U zbx_monitor -d postgres -f "/var/lib/zabbix/postgresql/pgsql.bgwriter.sql"'
    zabbix_agentd.log: 13949:20190820:101651.273 EXECUTE_STR() command:' psql -qtAX -h 127.0.0.1 -p 5432 -U zbx_monitor -d postgres -f "/var/lib/zabbix/postgresql/pgsql.bgwriter.sql"' len:291 cmd_result:'{"checkpoints_timed"'
    Any ideas how I can debug this further, does mean the checks aren't making it ?
    Zabbix Agent and Server version: 4.2.5
  • hokiecolt67
    • Aug 2019
    • 13
    mirtime - I'm new to this forum and I was looking at your post. Is it supposed to be ,"{$PG.DB}" and not ,"{$PG.D B}" Are you using macros to store the values? I would check that for the host having issues. Could be a spelling error or typo.
    • mlrtime
      • Aug 2019
      • 15
      I'm sorry that looks like a bug while pasting, here is the level 5 debug from server log
      14448:20190820:213528.864 In get_value_agent() host:'hostA' addr:'0.0.0.0' key:'system.cpu.util[,idle]' conn:'unencrypted'
      14450:20190820:213528.874 In get_value_agent() host:'hostA' addr:'0.0.0.0' key:'pgsql.config.hash["127.0.0.1","5432","zbx_monitor","postgres"]' conn:'unencrypted'
      14450:20190820:213528.876 Item [hostA:pgsql.config.hash["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"]] error: Unsupported item key.
      14440:20190820:213528.888 End of evaluate() error:'Cannot evaluate expression: "Cannot evaluate function "hostA:pgsql.config.hash["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"].strlen()": item is not supported.".'
      14440:20190820:213528.888 evaluate_expressions():expression [(ZBX_UNKNOWN1)=1 and (ZBX_UNKNOWN0)>0] cannot be evaluated: Cannot evaluate expression: "Cannot evaluate function "hostA:pgsql.config.hash["{$PG.HOST}","{$PG.PORT}","{$PG.USER}","{$PG.D B}"].strlen()": item is not supported.".
      I don't see anything in the agent log and zabbix_get works
      # zabbix_get -s hostA -p 10050 -k "pgsql.config.hash["127.0.0.1","5432","zbx_monitor","postgres"]"
      35ac93e301881fad0433ad008e330802
      • hokiecolt67
        • Aug 2019
        • 13
        mirtime - I would compare the macros for the system that works with the system that doesn't. Still could be a typo.
        • mlrtime
          • Aug 2019
          • 15
          Thanks for the suggestion, the host macros are all empty, the macros inherited from the template are all the defaults, they are identical between the two hosts.
          • mlrtime
            • Aug 2019
            • 15
            So my colleague found the problem.
            In Configuration->Hosts->Agent Interfaces the IP address was 0.0.0.0, as soon as we changed this to the ip address of the agent it worked.
            Even though, ListenIP=0.0.0.0 in zabbix_agentd.conf
            This also seems to be the default Agent interface when auto adding.
