ZABBIX - agent check - is unreachable for "x" time
  • karmukis
    • Aug 2014
    • 37
    HI,
    We are having problem with the
    "Zabbix agent on {HOST.NAME} is unreachable for 1 minutes", trigger.
    I kow there are many post about problems with this trigger, but in our case the trigger, when executed, it sends 2 messages, almost at the same time,
    1 for PROBLEM, saying that the agent is unreachable ;
    and a
    2 for an OK message, saying is reacheble again....
    we change the time check to 5 minutes, then 10.... and we are still seeing the error, but, of 9 servers we are having this issue with only 1 server....
    can you guide us to find the solution for this?
    May it be a bug?
    maay it be a bottle neck of some how in this particular server?
    thank you so much for the help.
  • tchjts1
    • May 2008
    • 1605
    On your Zabbix server, in zabbix_server.conf is a parameter called Timeout= that is set at a default value of 3. Try increasing that to 15 or 20, then restart your Zabbix server process.
    Note that for a new value to take effect, you either have to remove the # comment from that line, or create a new line with your new value that doesn't have the # comment preceding it.
    Secondly, have a look at this post https://www.zabbix.com/forum/showthread.php?t=41219 at the last paragraph which describes how to view your Zabbix internal processes. Possibly your system is overloaded and there are not enough pollers allocated to do the work.
    • karmukis
      • Aug 2014
      • 37
      Thank you so much for the answer.
      I did what you told me to and the problem persists.
      I change the TIMEOUT to 20, then addded more pollers, and
      even doe I did this, we still receive the alarms every five minutes, but what's annoying is
      that I receive the OK, and PROBLEM mails at the same time, and when I check the agent it is perfectly fine.
      What can it be?
      Again, thank you for all your help.
      kai
      • tchjts1
        • May 2008
        • 1605
        What version of the agent are you using?
        Did this start happening because of any upgrades?
        Do you have the proper agent installed? (32 or 64 bit)
        • karmukis
          • Aug 2014
          • 37
          Zabbix-Agent: zabbix-agent_2.2.4-1+wheezy_amd64.deb
          Zabbix Server: zabbix-2.2.5
          No, this is a brand new instalation.
          We are using the 64bit version, and yes it is the correct one, but as I mentioned before, this only happens in this server.
          To be honest I'm incline to think this must be a overload situation, or maybe a conf. problem...
          Again thank you so much for your help
