Cannot Authentication LDAP to Zabbix
  • bagas_w
    • Aug 2019
    Hello!
    I am trying to setup LDAP front end auth, but I am not having any luck.
    When I define the LDAP server, Bind DN, Base DN, etc and press "Test" or "Save" the page simply turns cannot bind to LDAP Server.
    Anyone having the same effect?
    Thanks in advance,
  • kloczek
    • Jun 2006
    • 1771
    In Base DN you must pass map to list of users.
    In my case it is "cn=users,cn=accounts,dc=example,dc=domain,dc= com"
    • Ashjoker
      • Sep 2019
      Hi all, I am trying to enable LDAP authentication in Zabbix server and i successfully tested it, but when i try to login the dashboard not allow ldap or admin authentication.
      • kloczek
        • Jun 2006
        • 1771
        I would reccoment to leave Admin account, change password and put that password in some vault (elecronic or physical).
        That user just in case should be always authenticated against zabbix native users database.
        If you want to restore original auth because still something is not working with LDAP auth you need to change this straight in database by execute query "update config set authentication_type = 0;" on your zabbix database.
        • Ashjoker
          • Sep 2019
          Even after changing update db with the query "config set authentication_type = 0;" i can't able to login with LDAP account
          • kloczek
            • Jun 2006
            • 1771
            No that update query is for disable LDAP authentication as default method.
            During experiments with adding LDAP auth settings is quite easy to loose access to zabbix frontend.
            That update query provides restore default auth to use zabbix local list of users.
