Good day.
Faced 2 problem. I am writing here because I can not register on support.zabbix.com (after entering data, the page always loads).
Error 1:
1.Create a template.
2. In it, we create a web verification script:
3. Create a verification step:
4. Create a trigger for this step:
5. We export by api in json format. I make it with bash script:
In response, we get:
6. We transfer this answer to another machine and tried to import:
I understand that it is enough to simply specify application in the web, but this field is not necessary and zabbix itself filled it like this: "application": null
Error 2:
1. Correct the first error and make the application.
2. After repeating step 5, we get another json:
3. Again we transfer and again we try to import the same code from step 6. This time we get an error:
And now I can’t imagine how to fix this. Maybe the community has ideas?
Thank you in advance.
Error 1:
#!/bin/bash auth=$(curl -s -H "Content-Type: application/json-rpc" -X POST 'localhost/zabbix/api_jsonrpc.php' -d ' {"jsonrpc": "2.0","method": "user.login","params": {"user": "Admin","password": "ХХХХХХХХХХХХ"},"id": 1,"auth": null}' | jq '.result') test=$(curl -s -H "Content-Type: application/json-rpc" -X POST 'zabbix-1/zabbix/api_jsonrpc.php' -d "{\"jsonrpc\": \"2.0\",\"method\": \"template.get\",\"params\": {\"output\": \"extend\",\"filter\": {\"host\": [\"Test\"]}},\"auth\": $auth,\"id\": 8}" | jq '.result[0].templateid') curl -s -H "Content-Type: application/json-rpc" -X POST 'zabbix-1/zabbix/api_jsonrpc.php' -d "{\"jsonrpc\": \"2.0\",\"method\": \"configuration.export\",\"params\": {\"options\": {\"templates\": [$test]},\"format\": \"json\"},\"auth\": $auth,\"id\": 14}" | jq '.result' > test.txt
"{\"zabbix_export\":{\"version\":\"4.2\",\"date\":\"2019-08-27T11:49:48Z\",\"groups\":[{\"name\":\"Test\"}],\"templates\":[{\"template\":\"Test\",\"name\":\"Test\",\"description\":\"\",\"groups\":[{\"name\":\"Test\"}],\"applications\":[],\"items\":[],\"discovery_rules\":[],\"httptests\":[{\"name\":\"Test\",\"application\":null,\"delay\":\"1m\",\"attempts\":\"1\",\"agent\":\"Zabbix\",\"http_proxy\":\"\",\"variables\":[],\"headers\":[],\"status\":\"0\",\"authentication\":\"0\",\"http_user\":\"\",\"http_password\":\"\",\"verify_peer\":\"0\",\"verify_host\":\"0\",\"ssl_cert_file\":\"\",\"ssl_key_file\":\"\",\"ssl_key_password\":\"\",\"steps\":[{\"name\":\"test\",\"url\":\"google.com\",\"query_fields\":[],\"posts\":[],\"variables\":[],\"headers\":[],\"follow_redirects\":\"1\",\"retrieve_mode\":\"0\",\"timeout\":\"15s\",\"required\":\"\",\"status_codes\":\"\"}]}],\"macros\":[],\"templates\":[],\"screens\":[],\"tags\":[]}],\"triggers\":[{\"expression\":\"{Test:web.test.rspcode[Test,test].last()}=0\",\"recovery_mode\":\"0\",\"recovery_expression\":\"\",\"name\":\"Test\",\"correlation_mode\":\"0\",\"correlation_tag\":\"\",\"url\":\"\",\"status\":\"0\",\"priority\":\"3\",\"description\":\"\",\"type\":\"0\",\"manual_close\":\"0\",\"dependencies\":[],\"tags\":[]}]}}"
#!/bin/bash auth=$(curl -s -H "Content-Type: application/json-rpc" -X POST 'localhost/zabbix/api_jsonrpc.php' -d ' {"jsonrpc": "2.0","method": "user.login","params": {"user": "Admin","password": "XXXXXXXXXXX"},"id": 1,"auth": null}' | jq '.result') export=$(< test.txt) curl -s -H "Content-Type: application/json-rpc" -X POST 'localhost/zabbix/api_jsonrpc.php' -d "{\"jsonrpc\": \"2.0\",\"method\": \"configuration.import\",\"params\": {\"format\": \"json\",\"rules\": {\"applications\": {\"createMissing\": true,\"deleteMissing\": false},\"discoveryRules\": {\"createMissing\": true,\"updateExisting\": true,\"deleteMissing\": true},\"graphs\":{\"createMissing\": true,\"updateExisting\": true,\"deleteMissing\": true},\"groups\": {\"createMissing\": true},\"hosts\": {\"createMissing\": true,\"updateExisting\": true},\"images\": {\"createMissing\": true,\"updateExisting\": true},\"items\": {\"createMissing\": true,\"updateExisting\": true,\"deleteMissing\": true},\"maps\":{\"createMissing\": true,\"updateExisting\": true},\"screens\":{\"createMissing\": true,\"updateExisting\": true},\"templateLinkage\":{\"createMissing\": true},\"templates\": {\"createMissing\": true,\"updateExisting\": true},\"templateScreens\":{\"createMissing\": true,\"updateExisting\": true,\"deleteMissing\": true},\"triggers\": {\"createMissing\": true,\"updateExisting\": true,\"deleteMissing\": true},\"valueMaps\": {\"createMissing\": true,\"updateExisting\": true}},\"source\": $export},\"auth\": $auth,\"id\": 12}"
{"jsonrpc":"2.0","error":{"code":-32500,"message":"Application error.","data":"Invalid tag \"/zabbix_export/templates/template(1)/httptests/httptest(1)/application\": an array is expected."},"id":12}
Error 2:
"{\"zabbix_export\":{\"version\":\"4.2\",\"date\":\"2019-08-27T12:12:39Z\",\"groups\":[{\"name\":\"Test\"}],\"templates\":[{\"template\":\"Test\",\"name\":\"Test\",\"description\":\"\",\"groups\":[{\"name\":\"Test\"}],\"applications\":[{\"name\":\"test\"}],\"items\":[],\"discovery_rules\":[],\"httptests\":[{\"name\":\"Test\",\"application\":{\"name\":\"test\"},\"delay\":\"1m\",\"attempts\":\"1\",\"agent\":\"Zabbix\",\"http_proxy\":\"\",\"variables\":[],\"headers\":[],\"status\":\"0\",\"authentication\":\"0\",\"http_user\":\"\",\"http_password\":\"\",\"verify_peer\":\"0\",\"verify_host\":\"0\",\"ssl_cert_file\":\"\",\"ssl_key_file\":\"\",\"ssl_key_password\":\"\",\"steps\":[{\"name\":\"test\",\"url\":\"google.com\",\"query_fields\":[],\"posts\":[],\"variables\":[],\"headers\":[],\"follow_redirects\":\"1\",\"retrieve_mode\":\"0\",\"timeout\":\"15s\",\"required\":\"\",\"status_codes\":\"\"}]}],\"macros\":[],\"templates\":[],\"screens\":[],\"tags\":[]}],\"triggers\":[{\"expression\":\"{Test:web.test.rspcode[Test,test].last()}=0\",\"recovery_mode\":\"0\",\"recovery_expression\":\"\",\"name\":\"Test\",\"correlation_mode\":\"0\",\"correlation_tag\":\"\",\"url\":\"\",\"status\":\"0\",\"priority\":\"3\",\"description\":\"\",\"type\":\"0\",\"manual_close\":\"0\",\"dependencies\":[],\"tags\":[]}]}}"
{"jsonrpc":"2.0","error":{"code":-32602,"message":"Invalid params.","data":"Incorrect item key \"web.test.rspcode[Test,test]\" provided for trigger expression on \"Test\"."},"id":12}
