Zabbix Not Discovering Hypervisors/VMs using Template VM VMware
  • Clontarf[X]
    • Jan 2017
    • 80
    Configuration
    Started 10 VMware Collectors
    Created host for vSphere (8615VVC001) (vSphere Client version 6.7.0.40000)
    Assigned Agent Interface IP 127.0.0.1
    Assigned "Template VM VMware" Template
    Created Macros {$URL}.{$USERNAME} and {$PASSWORD}
    Testing
    Clicked "Check Now" on Host's discoveries to force a check
    Event log item becomes unsupported "Cannot find items in performance counter list"
    Notes
    The only difference is https://8615VVC001/sdk doesn't exist, but https://8615VVC001/api does. So I am using /api as the URL.
    Logs
    8222:20190830:123632.945 In vmware_service_update() '[email protected]'@'https://8615VVC001.cewa.edu.au/api'
    8225:20190830:123632.945 __zbx_zbx_setproctitle() title:'vmware collector #5 [updated 0, removed 0 VMware services in 0.000199 sec, querying VMware services]'
    8225:20190830:123632.945 __zbx_zbx_setproctitle() title:'vmware collector #5 [updated 0, removed 0 VMware services in 0.000255 sec, idle 5 sec]'
    8230:20190830:123632.946 __zbx_zbx_setproctitle() title:'vmware collector #10 [updated 0, removed 0 VMware services in 0.000128 sec, querying VMware services]'
    8226:20190830:123632.946 __zbx_zbx_setproctitle() title:'vmware collector #6 [updated 0, removed 0 VMware services in 0.000104 sec, querying VMware services]'
    8226:20190830:123632.946 __zbx_zbx_setproctitle() title:'vmware collector #6 [updated 0, removed 0 VMware services in 0.000888 sec, idle 5 sec]'
    8230:20190830:123632.946 __zbx_zbx_setproctitle() title:'vmware collector #10 [updated 0, removed 0 VMware services in 0.000976 sec, idle 5 sec]'
    8223:20190830:123632.947 __zbx_zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.000710 sec, querying VMware services]'
    8223:20190830:123632.947 __zbx_zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.001029 sec, idle 5 sec]'
    8228:20190830:123632.947 __zbx_zbx_setproctitle() title:'vmware collector #8 [updated 0, removed 0 VMware services in 0.000366 sec, querying VMware services]'
    8228:20190830:123632.947 __zbx_zbx_setproctitle() title:'vmware collector #8 [updated 0, removed 0 VMware services in 0.000941 sec, idle 5 sec]'
    8227:20190830:123632.947 __zbx_zbx_setproctitle() title:'vmware collector #7 [updated 0, removed 0 VMware services in 0.000194 sec, querying VMware services]'
    8227:20190830:123632.947 __zbx_zbx_setproctitle() title:'vmware collector #7 [updated 0, removed 0 VMware services in 0.000170 sec, idle 5 sec]'
    8229:20190830:123632.948 __zbx_zbx_setproctitle() title:'vmware collector #9 [updated 0, removed 0 VMware services in 0.000108 sec, querying VMware services]'
    8229:20190830:123632.948 __zbx_zbx_setproctitle() title:'vmware collector #9 [updated 0, removed 0 VMware services in 0.000215 sec, idle 5 sec]'
    8224:20190830:123632.948 __zbx_zbx_setproctitle() title:'vmware collector #4 [updated 0, removed 0 VMware services in 0.000597 sec, querying VMware services]'
    8222:20190830:123632.948 In vmware_service_authenticate() '[email protected]'@'https://8615VVC001.cewa.edu.au/api'
    8224:20190830:123632.948 __zbx_zbx_setproctitle() title:'vmware collector #4 [updated 0, removed 0 VMware services in 0.000130 sec, idle 5 sec]'
    8221:20190830:123632.948 __zbx_zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000636 sec, querying VMware services]'
    8221:20190830:123632.948 __zbx_zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000444 sec, idle 5 sec]'
    8222:20190830:123632.986 End of vmware_service_authenticate():SUCCEED
    8222:20190830:123632.986 In vmware_service_get_hv_ds_list()
    8222:20190830:123633.019 End of vmware_service_get_hv_ds_list():SUCCEED found hv:0 ds:0
    8222:20190830:123633.019 In vmware_service_get_cluster_list()
    8222:20190830:123633.019 In vmware_service_get_clusters()
    8222:20190830:123633.049 End of vmware_service_get_clusters():SUCCEED
    8222:20190830:123633.050 End of vmware_service_get_cluster_list():SUCCEED found:0
    8222:20190830:123633.050 In vmware_service_get_maxquerymetrics()
    8222:20190830:123633.079 maxQueryMetrics used default value 64
    8222:20190830:123633.080 End of vmware_service_get_maxquerymetrics():SUCCEED
    8222:20190830:123633.117 In vmware_service_update_perf_entities()
    8222:20190830:123633.117 End of vmware_service_update_perf_entities() entities:0
    8222:20190830:123633.117 End of vmware_service_update():SUCCEED processed:102400 bytes of data
    8222:20190830:123633.117 In vmware_service_update_perf() '[email protected]'@'https://8615VVC001.cewa.edu.au/api'
    8222:20190830:123633.118 In vmware_service_authenticate() '[email protected]'@'https://8615VVC001.cewa.edu.au/api'
    8222:20190830:123633.165 End of vmware_service_authenticate():SUCCEED
    8222:20190830:123633.165 In vmware_service_retrieve_perf_counters() counters_max:1000
    8222:20190830:123633.165 End of vmware_service_retrieve_perf_counters()
    8222:20190830:123633.165 In vmware_service_retrieve_perf_counters() counters_max:64
    8222:20190830:123633.196 In vmware_service_copy_perf_data()
    8222:20190830:123633.196 End of vmware_service_copy_perf_data()
    8222:20190830:123633.196 End of vmware_service_update_perf():SUCCEED processed 204800 bytes of data
    8222:20190830:123633.196 __zbx_zbx_setproctitle() title:'vmware collector #2 [updated 2, removed 0 VMware services in 0.251041 sec, idle 5 sec]'
    8225:20190830:123637.946 __zbx_zbx_setproctitle() title:'vmware collector #5 [updated 0, removed 0 VMware services in 0.000255 sec, querying VMware services]'
    8225:20190830:123637.946 __zbx_zbx_setproctitle() title:'vmware collector #5 [updated 0, removed 0 VMware services in 0.000211 sec, idle 5 sec]'
    8226:20190830:123637.947 __zbx_zbx_setproctitle() title:'vmware collector #6 [updated 0, removed 0 VMware services in 0.000888 sec, querying VMware services]'
    8226:20190830:123637.947 __zbx_zbx_setproctitle() title:'vmware collector #6 [updated 0, removed 0 VMware services in 0.000138 sec, idle 5 sec]'
    8230:20190830:123637.947 __zbx_zbx_setproctitle() title:'vmware collector #10 [updated 0, removed 0 VMware services in 0.000976 sec, querying VMware services]'
    8230:20190830:123637.947 __zbx_zbx_setproctitle() title:'vmware collector #10 [updated 0, removed 0 VMware services in 0.000244 sec, idle 5 sec]'
    8228:20190830:123637.947 __zbx_zbx_setproctitle() title:'vmware collector #8 [updated 0, removed 0 VMware services in 0.000941 sec, querying VMware services]'
    8228:20190830:123637.948 __zbx_zbx_setproctitle() title:'vmware collector #8 [updated 0, removed 0 VMware services in 0.000125 sec, idle 5 sec]'
    8223:20190830:123637.948 __zbx_zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.001029 sec, querying VMware services]'
    8223:20190830:123637.948 __zbx_zbx_setproctitle() title:'vmware collector #3 [updated 0, removed 0 VMware services in 0.000370 sec, idle 5 sec]'
    8227:20190830:123637.948 __zbx_zbx_setproctitle() title:'vmware collector #7 [updated 0, removed 0 VMware services in 0.000170 sec, querying VMware services]'
    8227:20190830:123637.948 __zbx_zbx_setproctitle() title:'vmware collector #7 [updated 0, removed 0 VMware services in 0.000149 sec, idle 5 sec]'
    8229:20190830:123637.948 __zbx_zbx_setproctitle() title:'vmware collector #9 [updated 0, removed 0 VMware services in 0.000215 sec, querying VMware services]'
    8229:20190830:123637.948 __zbx_zbx_setproctitle() title:'vmware collector #9 [updated 0, removed 0 VMware services in 0.000192 sec, idle 5 sec]'
    8224:20190830:123637.949 __zbx_zbx_setproctitle() title:'vmware collector #4 [updated 0, removed 0 VMware services in 0.000130 sec, querying VMware services]'
    8224:20190830:123637.949 __zbx_zbx_setproctitle() title:'vmware collector #4 [updated 0, removed 0 VMware services in 0.000165 sec, idle 5 sec]'
    8221:20190830:123637.949 __zbx_zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000444 sec, querying VMware services]'
    8221:20190830:123637.949 __zbx_zbx_setproctitle() title:'vmware collector #1 [updated 0, removed 0 VMware services in 0.000115 sec, idle 5 sec]'
    8222:20190830:123638.196 __zbx_zbx_setproctitle() title:'vmware collector #2 [updated 2, removed 0 VMware services in 0.251041 sec, querying VMware services]'
    8222:20190830:123638.196 __zbx_zbx_setproctitle() title:'vmware collector #2 [updated 0, removed 0 VMware services in 0.000124 sec, idle 5 sec]'
  • Hamardaban
    • May 2019
    • 2714
    api & sdk - the big difference! Look for the internet how to make available SDK for your version vmware.
    • Clontarf[X]
      • Jan 2017
      • 80
      Thanks, I found some instructions on enabling the /sdk endpoint. Now I get "no headers, no data".
      The logs show failing to authenticate;
      8746:20190830:151116.361 In vmware_service_update() '[email protected]'@'http://8615vvc001.cewa.edu.au:5480/sdk'
      8746:20190830:151116.361 In vmware_service_authenticate() '[email protected]'@'http://8615vvc001.cewa.edu.au:5480/sdk'
      8745:20190830:151116.367 __zbx_zbx_setproctitle() title:'vmware collector #6 [updated 0, removed 0 VMware services in 0.000103 sec, querying VMware servic
      es]'
      8745:20190830:151116.367 __zbx_zbx_setproctitle() title:'vmware collector #6 [updated 0, removed 0 VMware services in 0.000093 sec, idle 5 sec]'
      8746:20190830:151116.367 End of vmware_service_authenticate():FAIL
      8746:20190830:151116.367 In vmware_service_update_perf_entities()
      8746:20190830:151116.367 End of vmware_service_update_perf_entities() entities:0
      8746:20190830:151116.367 End of vmware_service_update():FAIL processed:102400 bytes of data
      8746:20190830:151116.367 __zbx_zbx_setproctitle() title:'vmware collector #7 [updated 1, removed 0 VMware services in 0.006291 sec, idle 5 sec
      I am certain that the credentials are correct. Thanks
