Wrong free swap space from centos server
  • syco
    • Jul 2018
    One of the servers I monitor is reporting the wrong swap size, both server and agent are version 4.2
    The client server is a container hosted on LXC.
    Attached a screenshot with the values from zabbix interface, I get the same values using zabbix_get and system.swap.size[,pfree]
    and this is what I get from the client server command line:
    $ free -h
                  total        used        free      shared  buff/cache   available
    Mem:           4.0G        1.4G        2.3G         96M        320M        2.6G
    Swap:          8.0G        168M        7.8G
    As you can see the total swap space is correct, but the free swap space and the total memory are not.
    Does someone know what could cause it?
  • kloczek
    • Jun 2006
    • 1771
    You are probably looking on wrong host or collecting data from wrong host.
    • roberdaniel
      • Apr 2019
      • 22
      Hi all
      I'm having similar problems with windows environments.
      The amount of swap used is not the same as you can see in permon.msc.
      Both server and client are 4.4.8
      Here some pics
      Windows says
      but Zabbix says
      Any ideas?
