ICMP Ping Trigger error
  • WilliamSG
    • Jun 2014
    • 41
    Hi ppl!
    I'm Issuing a curious problem... all of my hosts are showing ICMP Trigger status error, but if I ran the GUI Ping (or from console) it works fine.
    Trigger status
    Trigger setup
    GUI Ping exemple
    Anyone have any idea why it's happening?
  • WilliamSG
    • Jun 2014
    • 41
    is 0 = down and 1 = up ?
    There isn't a value mapping for ICMP. Where can I check this information?
    • evertonco
      • Aug 2014
      • 75
      Did you look the collected values of icmpping item of host on "Latest Data" page?
      • bbrendon
        • Sep 2005
        • 873
        Not sure if its clear but GUI ping is in almost no way related to "ICMP Trigger status error".
        At least in how it works inside zabbix.
        Unofficial Zabbix Expert
        Blog, Corporate Site
        • WilliamSG
          • Jun 2014
          • 41
          Yes, value is "Up (0)", and the grafh shows 0 all the time.
          Different while compared with "Agent Ping" that shows "Up(1)".
          If I put the host down, icmping doesn't change, and Agent ping change to "Up(0), means agent ping is working fine, but not the icmpping.
          • evertonco
            • Aug 2014
            • 75
            Zabbix 2.2 Manual :: Simple Checks
            0 - ICMP ping fails (host is down)
            1 - ICMP ping successful
            Apparently, the trigger is configured correctly and should indicate that host is down. So, the problem could be fping configuration or permissions.
            Check the zabbix server logs and go to "Latest Data" and mark the "show items without data" and "show details" options to see Error column.
            • WilliamSG
              • Jun 2014
              • 41
              Apparently fping is ok, it's working from console, and is in correct folder, the permissions are 4755 and owner are root.
              At latest data, when I aplly those filters, ICMP itens aren't showed.
              I was reading a post about times and delays, I will check it and post reply, unfortunely I can't do it now...
              • WilliamSG
                • Jun 2014
                • 41
                Maybe this is an internal issue... ?
                • evertonco
                  • Aug 2014
                  • 75
                  What version of your zabbix server and SO?
                  Here, I use zabbix 2.2.2 (upgraded from zabbix 2.0.2) on Debian 7 and ping works perfectly.
                  • WilliamSG
                    • Jun 2014
                    • 41
                    CentOS 6.5 and Zabbix 2.2.5.
                    • WilliamSG
                      • Jun 2014
                      • 41
                      Hi guys, good news, I solved the problem.
                      IDK why, but I need to run "setenforce 0" on proxy too.
                      In the past I was with a problem to send mails on my server, after running setenforce 0, that problem was solved, and now, this same command solved my ping problem.
