I'm setting up Zabbix on my virtual machine however its failing to start after I finished installing it.
This is the output after I enter sudo systemctl status zabbix-server
zabbix-server.service - Zabbix Server
Loaded: loaded (usr/lib/systemd/system/zabbix-server.service; enabled; vendor preset: disabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2019-09-09 07:38:05 EDT; 2s ago
Process: 14342 ExecStop=/bin/kill -SIGTERM $MAINPID (code=exited, status=1/FAILURE)
Process: 14301 ExecStart=/usr/sbin/zabbix_server -c $CONFFILE (code=exited, status=0/SUCCESS)
Main PID: 14303 (code=exited, status=0/SUCCESS)
Sep 09 07:38:05 localhost.localdomain systemd[1]: zabbix-server.service: Control process exited, code=exited status=1
Sep 09 07:38:05 localhost.localdomain systemd[1]: Unit zabbix-server.service entered failed state.
Sep 09 07:38:05 localhost.localdomain systemd[1]: zabbix-server.service failed
