[SOLVED]
Solution: In the 4.2.6 version a default database password was set in the file zabbix/web/zabbix.conf.php
Hi, new here - so please bear with me
OS Ubuntu 18.04LTS
Today I upgraded my Zabbix from 4.0.9 to 4.2.6
When trying to access web UI afterwards I am getting "Error connecting to database: Access denied for user 'zabbix'@'localhost' (using password: YES)"
* In /var/log/zabbix/zabbix_server.log everything seems to be running fine and it is connecting to the database. I also can see my items becoming supported in the log.
* I am able to connect to the database using the credentials from zabbix_server.conf from Chrome MySQL-Admin.
* If I change the mysql-credentials in zabbix_server.conf I can see in the log that zabbix is not able to connect to mySQL.
* If I remove the password from mySQL and zabbix_server.conf I still get the "(using password: YES)"-error
* I have granted all rights on the zabbix dbuser and flushed privileges after every password change on mysql
Is there some other place where the database credentials needs to be updated?
And yes, I do restart the zabbix-server service between every test
Zabbix Agent is turned off
Anyone with any good advice what is causing this?
OS Ubuntu 18.04LTS
