Zabbix Agent Can't be Contacted
  • red_smeg
    • Sep 2019
    I have a self hosted Zabbix server with multiple hosts (CENTOS & FREEBSD) These have been working perfectly on zabbix 32 for a couple of years. I had to upgrade the Freebsd servers to version 12 and this also required I got to zabbix 42 on the agent end. Ever since then (with no zabbix agent changes in config) the servers give an error message that the zabbix agent can't be contacted, even though the events, like apache down or up are triggering normally.
    Its there something I should do at the server end ? it is showing 3.4.2 on the front page of the web portal at the server.
  • red_smeg
    • Sep 2019
    Also getting this message one the hosts page
    "Received empty response from Zabbix Agent at [10.136.45.72]. Assuming that agent dropped connection because of access permissions."
    • Atsushi
      • Aug 2013
      • 2028
      If the Zabbix server is using version 3.4.2, the Zabbix agent version must be 3.4 or earlier. Try using a version 3.4 agent.
      • red_smeg
        • Sep 2019
        I think I'll have to upgrade the server. I had to upgrade the agents as they wouldn't work on freebsd 12 as there was a missing lib.
        • lukaszor
          • Jun 2018
          • 17
          Run the Zabbix Agent in the debug mode and check the logs for more informations
