zabbix proxy on beaglebone
  • AksarBhai
    • Sep 2019
    Hello everyone,,
    I have installed the debian stretch image on my beaglebone. After the standard dependencie hell, i have zabbix proxy and mysql running.
    DB is created and i have to zcat the db schema.
    Problem is the /usr/share/doc/zabbix-proxy-mysql folder does not contain the scheme file.
    Is there anyone who Balance Credit can tell why that is? and where i can get the right scheme file?
    Oh and any suggestions to create cheaper proxies? The beaglebone black is around 80 euro with case. When done setting it up on the sd card i'll flsh it to the internal 2GB emm flash. Is 2GB enough for a zabbix proxy?
    best regards,.
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Are you using docker? It is known that sometimes docker images are configured to skip documentation files (/usr/share/doc/*) by default, to save space. Here's an example of such issue: https://support.zabbix.com/browse/ZBX-14820
