Queue 01-01-1970 and patch
  • WilliamSG
    • Jun 2014
    • 41
    Hi again!
    I'm with a new issue, some itens of my environment are not working because they are in queue marked with 01-01-1970, (...) resuming, this is a know issue, more details see here
    The support team tells us to apply the patch r48223, I'm trying to apply the patch, but I don't know wich file I need to patch.
    Can anyone tell me wich file I need to apply the patch?
  • ingus.vilnis
    • Mar 2014
    • 908
    The patch is included in the latest stable 2.2.6 version (released yesterday) as well. You should consider updating the whole system if you are having issues with applying the patch only.
    P.S. If support team has advised you to use the patch but you have additional questions, please don't hesitate to ask them for more help.
    Best Regards,
    Ingus
    • WilliamSG
      • Jun 2014
      • 41
      Tank you!
      But I was trying to update by packages, and I'm receving this error:
      Total download size: 718 k
      Downloading Packages:
      (1/4): zabbix-2.2.6-1.el6.x86_64.rpm | 146 kB 00:01
      http://repo.zabbix.com/zabbix/2.2/rh...l6.x86_64.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
      Trying other mirror.
      (2/4): zabbix-agent-2.2.6-1.el6.x86_64.rpm | 156 kB 00:02
      (3/4): zabbix-proxy-2.2.6-1.el6.x86_64.rpm | 20 kB 00:00
      (4/4): zabbix-proxy-mysql-2.2.6-1.el6.x86_64.rpm | 398 kB 00:03
      Error Downloading Packages:
      zabbix-2.2.6-1.el6.x86_64: failure: zabbix-2.2.6-1.el6.x86_64.rpm from zabbix: [Errno 256] No more mirrors to try.
      zabbix-agent-2.2.6-1.el6.x86_64: failure: zabbix-agent-2.2.6-1.el6.x86_64.rpm from zabbix: [Errno 256] No more mirrors to try.
      zabbix-proxy-2.2.6-1.el6.x86_64: failure: zabbix-proxy-2.2.6-1.el6.x86_64.rpm from zabbix: [Errno 256] No more mirrors to try.
      zabbix-proxy-mysql-2.2.6-1.el6.x86_64: failure: zabbix-proxy-mysql-2.2.6-1.el6.x86_64.rpm from zabbix: [Errno 256] No more mirrors to try.
      I ran the clean metadata but error persists. Is it an internal mirror error?
      • ingus.vilnis
        • Mar 2014
        • 908
        Originally posted by WilliamSG
        Tank you!
        The Zabbix repo is working fine as far as I know. http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/
        I don't know what caused you these errors, sorry. The only thing I see that the hyperlinks in your reply have ":" in the end but not likely that was the problem.
        • dvwyngaa
          • Mar 2014
          • 49
          Ingus,
          I have the same problem with the repo as William described. I have cleared my yum, updated and still getting the same problem.
          Any suggestions?
          Dawid
          • ingus.vilnis
            • Mar 2014
            • 908
            Originally posted by dvwyngaa
            Ingus,
            Any suggestions?
            Dawid
            Dawid,
            I don't have a test CentOS instance at the moment so I can't test it but I could try to check this issue later.
            Best Regards,
            Ingus
            • istok
              • Aug 2014
              I have this problems too. Cant install Zabbix
              (1/4): zabbix-server-2.2.6-1.el6.x86_64.rpm | 20 kB 00:00
              (2/4): zabbix-server-mysql-2.2.6-1.el6.x86_64.rpm | 1.5 MB 00:02
              (3/4): zabbix-web-2.2.6-1.el6.noarch.rpm | 4.5 MB 00:10
              http://repo.zabbix.com/zabbix/2.2/rh...l6.noarch.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
              (4/4): zabbix-web-mysql-2.2.6-1.el6.noarch.rpm | 13 kB 00:00
              zabbix-server-mysql-2.2.6-1.el6.x86_64: failure: zabbix-server-mysql-2.2.6-1.el6.x86_64.rpm from zabbix: [Errno 256] No more mirrors to try.
              zabbix-server-2.2.6-1.el6.x86_64: failure: zabbix-server-2.2.6-1.el6.x86_64.rpm from zabbix: [Errno 256] No more mirrors to try.
              zabbix-web-mysql-2.2.6-1.el6.noarch: failure: zabbix-web-mysql-2.2.6-1.el6.noarch.rpm from zabbix: [Errno 256] No more mirrors to try.
              zabbix-web-2.2.6-1.el6.noarch: failure: zabbix-web-2.2.6-1.el6.noarch.rpm from zabbix: [Errno 256] No more mirrors to try.
              • WilliamSG
                • Jun 2014
                • 41
                I started a new VM and installed clean CentOS 6.5 and got the same error.
                • WilliamSG
                  • Jun 2014
                  • 41
                  Good news (maybe) In my new VM I instaled the proxy from sources with the same confs and now my queue is drecreasing... I need to wait 1h to check if the problem is fully solved.
                  BUT!
                  The error when trying to install from packages persists, probably it's an internal error from repo X CentOS.
                  I'll be back after lunch time
                  • Joker85
                    • Aug 2014
                    The same problem,
                    (1/5): zabbix-2.2.6-1.el6.x86_64.rpm        | 146 kB     00:00
                    http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/zabbix-2.2.6-1.el6.x86_64.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
                    (2/5): zabbix-server-2.2.6-1.el6.x86_64.rpm        |  20 kB     00:00
                    http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/zabbix-server-2.2.6-1.el6.x86_64.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
                    (3/5): zabbix-server-mysql-2.2.6-1.el6.x86_64.rpm        | 1.5 MB     00:00
                    http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/zabbix-server-mysql-2.2.6-1.el6.x86_64.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
                    (4/5): zabbix-web-2.2.6-1.el6.noarch.rpm        | 4.5 MB     00:04
                    http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/zabbix-web-2.2.6-1.el6.noarch.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
                    (5/5): zabbix-web-mysql-2.2.6-1.el6.noarch.rpm        |  13 kB     00:00
                    http://repo.zabbix.com/zabbix/2.2/rhel/6/x86_64/zabbix-web-mysql-2.2.6-1.el6.noarch.rpm: [Errno -1] Package does not match intended download. Suggestion: run yum --enablerepo=zabbix clean metadata
                    • ingus.vilnis
                      • Mar 2014
                      • 908
                      Problem with 2.2.6 packages should be solved.
                      Please check now.
                      Best Regards,
                      Ingus
                      • WilliamSG
                        • Jun 2014
                        • 41
                        Working with proxy. thx.
                        With the Server, I received a message telling the Zabbix-server is up-to-date.
                        Loaded plugins: fastestmirror
                        # yum -y install zabbix-server
                        Loading mirror speeds from cached hostfile
                        * base: centosc5.centos.org
                        * extras: centosb6.centos.org
                        * updates: centosb5.centos.org
                        Setting up Install Process
                        Package zabbix-server-2.2.5-1.el6.x86_64 already installed and latest version
                        Nothing to do
                        • dvwyngaa
                          • Mar 2014
                          • 49
                          Yip...I'm getting the same here...Proxy works, but not the server...
                          Dawid
