Zabbix_get showing different value than latest data (Raw data)
  • mlrtime
    • Aug 2019
    • 15
    I have a host with about 747GB of Memory and around 476GB available. I understand how zabbix calculates available memory (https://www.zabbix.com/documentation...ry.size_params). I'm getting a completely different number in raw numbers than zabbix_get
    Example:
    # zabbix_get -s HOST -p 10050 -k "vm.memory.size[used]"
    476883517440
    Latest Data:
    It looks to me as if the value is too large for the data type in the database
  • mlrtime
    • Aug 2019
    • 15
    Bump, any ideas? Anyone know how I can get the query that this returns, should it be the exact value from zabbix_get?
    • Atsushi
      • Aug 2013
      • 2028
      I can't read the text on the attached image file, so I don't know what is different.
      Please tell me what OS you are using and what value you want to get. Depending on the OS being used, the size of the available memory can be checked using the following key.
      ex.
      vm.memory.size[available]
      • mlrtime
        • Aug 2019
        • 15
        Thank you for responding.
        Here is the value from zabbix_get
        Example:
        476883517440
        Here is the values I get in HOST->Items->Latest data->Memory (Available memory)->Graph->Values
        09/24/2019 07:34:21 AM 6596272128
        09/24/2019 07:33:21 AM 6580867072
        09/24/2019 07:32:21 AM 6586548224
        09/24/2019 07:31:22 AM 6585708544
        09/24/2019 07:30:21 AM 6586400768
        The values from zabbix_get are not the same as the data shown.
        HOST is Centos 7 3.10.0 kernel
        Zabbix is Centos 7.6 3.10.0 kernel
        I'd like to why there is a discrepancy between zabbix_get values and what I see in the UI
        • dimir
          Zabbix developer
          • Apr 2011
          • 1080
          I assume you are sure you are pointing zabbix_get exactly to the same agent that handles host in the graph?
          • mlrtime
            • Aug 2019
            • 15
            Yes, I double checked, I'm obscuring the hostname for simplicity. But yeah, I copy the hostname from the graph page to the zabbix_get and get different values. The graph is 'Memory (Available Memory)' and the get is vm.memory.size[available], I haven't changed the template.
            • dimir
              Zabbix developer
              • Apr 2011
              • 1080
              Wait, but available and used are different things, right?
              • mlrtime
                • Aug 2019
                • 15
                Argh, typo in the post (doesn't help my case). Here are the values, wrong value for available in values from UI
                # zabbix_get -s HOST -p 10050 -k "vm.memory.size[available]"
                789995679744
                685048332288
                Available memory Values from UI
                09/24/2019 08:47:21 AM 6587539456
                09/24/2019 08:46:21 AM 6595207168
                It doesn't look like used memory is a item captured in the Template OS linux
                • dimir
                  Zabbix developer
                  • Apr 2011
                  • 1080
                  Just out of curiosity, what if you use zabbix_agentd binary on target host, instead of zabbix_get:
                  # sudo -u zabbix_agentd -t vm.memory.size[used]
                  # sudo -u zabbix_agentd -t vm.memory.size[available]
                  • mlrtime
                    • Aug 2019
                    • 15
                    Same values as zabbix_get
                    # zabbix_agentd -t vm.memory.size[available] ; zabbix_agentd -t vm.memory.size[used]
                    vm.memory.size[available] [u|792433606656]
                    vm.memory.size[used] [u|682677321728]
                    • dimir
                      Zabbix developer
                      • Apr 2011
                      • 1080
                      Looks like some restrictions issue, is there anything like SELinux running on target host?
                      • mlrtime
                        • Aug 2019
                        • 15
                        # getenforce
                        Disabled
                        On client and Zabbix Server
                        The values match on the server and the client, my guess is that the datatype in the db is wrong and truncating. How can I get the exact query that this page uses?
                        • dimir
                          Zabbix developer
                          • Apr 2011
                          • 1080
                          The numbers that UI shows (e. g. 6587539456) would not fit into Integer, so I doubt it's a database issue. Could you run the zabbix_agentd -t commands with sudo -u zabbix as I specifically mentioned? This way we are sure the values are fetched by the same user as the agent is running as.
                          • DARKINATY
                            • Sep 2019
                            • mlrtime
                              • Aug 2019
                              • 15
                              #15
                              So this is fixed but I never found the root cause. I upgrade the server and agent to 4.4 and now UI is showing the proper 600GB ram available. I'm assuming this is a zabbix bug
