Couldn't extract value with JSONPath.
  • greendruid
    • Feb 2018
    Hi!
    I try to extract value of `ValueCSV` from the next construction:
    "MetricName": "net.multicastRx.summation",
    "MetricInstance": "-",
    "ValueCSV": "7",
    "Units": "num"
    (this is the array with unique values of 'MetricName')
    I'm use the next sequence: `$.VMMetrics[?(@.MetricName == "net.packetsTx.summation")].ValueCSV`, but Zabbix show an exclamation.
    Does anyone faced with similar parsing tasks?
    Thanks!
  • Atsushi
    • Aug 2013
    • 2028
    In the JSON where the value of MetricName is exemplified, it is “net.multicastRx.summation”, but the value of MetricName specified in JSONPath is “net.packetsTx.summation”. It doesn't match, but make sure that the record you want to get is included in the JSON.
    And what version of Zabbix is used? Is it 4.2.5 or later? Or Is it 4.0.11 or later?
    ZBXNEXT-4502 : Support of 'advanced' JSON Path expressions
