zabbix_get is OK but zabbix logs display an error
  • Erwan A.
    • Jun 2019
    I want to monitor ipsec's tunnel on my PFSense.
    I used a template from here : https://github.com/anapsix/zabbix-haproxy
    Configuration done so I try a test from my zabbix server with : zabbix_get -s xxx.xxx.xxx.xxx -k 'ipsec.discover'
    I get someting like this :
    "data":[
    { "{#TUNNEL}":"con20071","{#TARGETIP}":" xxx.xxx.xxx.xxx","{#SOURCEIP}":" xxx.xxx.xxx.xxx","{#DESCRIPTION}":"Not found" },
    { "{#TUNNEL}":"con1001","{#TARGETIP}":" xxx.xxx.xxx.xxx","{#SOURCEIP}":" xxx.xxx.xxx.xxx","{#DESCRIPTION}":"Foliateam Network" },
    { "{#TUNNEL}":"con20059","{#TARGETIP}":" xxx.xxx.xxx.xxx","{#SOURCEIP}":" xxx.xxx.xxx.xxx","{#DESCRIPTION}":"Not found" },
    Sounds good, i was proud of me !
    But when i add this template in zabbix and apply it to my PFSense, no new items were created, ipsec.discover seem KO.
    I checked my zabbix logs and found this :
    {"log":" 454:20190925:173620.533 Zabbix agent item "ipsec.discover" on host "pfSense-Prod" failed: first network error, wait for 15 seconds\n","stream":"stdout","time":"2019-09-25T15:36:20.534553063Z"}
    {"log":"\n","stream":"stdout","time":"2019-09-25T15:36:20.534578315Z"}
    How could this be possible ?
    Zabbix_get from my zabbix server is OK but it's KO in logs and zabbix server didn't discover tunnels?
  • Erwan A.
    • Jun 2019
    Zabbix server : 3.4
    [root@fe94519d0b5a /]# zabbix_server -V
    zabbix_server (Zabbix) 3.4.9 Dockbix XXL (2018-06-21)
    Revision 80550 9 May 2018, compilation time: Jun 21 2018 07:47:49
    Zabbix agent on pfsense : 3.4
    Template we use is OK on our test pfsense, ipsec.discover work great, and zabbix agent is 3.4
