hello everyone,
i am trying to work with network interfaces discovery and trigger them in order to have notifications to my mail.
the problem is that the discovery process discover many many fiction interfaces or duplicate ones that are not active or just give me multiple alarms for the same issue.
i made my research in order to check for it, to look for a solution but the only one i found in the web(and correct me if im wrong here) is {#IFNAME} which doesn't really do much for help here.
so the only thing i left with is letting the discovery rule discover it's best and then disable it and move to delete the interfaces i do not want.
but then i have new problem poped up in the info status for items - "The item is not discovered anymore and will be deleted in 8d 22h 45m (on 10/08/2019 at 09:35 AM)."
so im kinda sitting here, helpless,
what do i have to do? keep the discovery rule on in order to have the right items and triggers not automaticlly deleted after few days but having useless and annoying ones being created in the background
do i have to keep it disabled and enable it once everytime its getting deleted and let it recreate it and also recreate bunch of them useless items and triggers in the process?
i kinda lose all of the point having automated monitoring system.
is there any solution in a form of a new macro/filter to make the discovery rule discover only active interfaces?
