First installation in raspbian fails
  • LeandroWagner1981
    • Sep 2019
    Hi ! Several times I installed 4.0 in ubuntu, but now I'm installing 4.2.6 in Raspbian and can't get through the installation. Frontend works, but Zabbix Server is not running.
    systemctl status zabbix-server only shows:
    "Loaded: masked (Reason: Unit zabbix-server.service is masked.)"
    start message is the same, event after unmasked it.
    Every time i tried to unmasked seems to be doesn't work.
    Logs are empty as well.
    Any kind of suggestion or comment or idea on how advance on the resolution or see the real reason, or solve the problem will be thankd in avance!
    Kind regards,
    Lean
