Agent Installation steps for AIX servers
  • kerem.yarali
    • Sep 2019
    • 23
    Hello
    I'm going to install Zabbix agents for AIX servers . However, I could not find detail steps.
    Is it possible to share the agent installation steps for AIX servers with me?
    Regards
  • kloczek
    • Jun 2006
    • 1771
    Steps are exactly the same as on any other system.
    Download source -> configure source -> compile -> install -> use.
    • kerem.yarali
      • Sep 2019
      • 23
      Hello
      I haven’t any agent installation experience on AIX servers.
      Is there a manuel guide for agent installation?
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        We have pre-compiled agents for AIX 6.1 and 7.2: https://www.zabbix.com/download_agents (select "Zabbix Agents" on the right).
        • kerem.yarali
          • Sep 2019
          • 23
          Hello dimir
          I checked agent packages from download side.
          I want to learn, which commands should I run on command line? Could you help me?
          • dimir
            Zabbix developer
            • Apr 2011
            • 1080
            No, sorry. I'm not an AIX user. If you have budget you can get help from our support: https://zabbix.com/support
            • andris
              Zabbix developer
              • Feb 2012
              • 228
              On https://www.zabbix.com/download_agents#tab:42 you can find precompiled AIX agents 4.2.1 for AIX 6.1, 7.2.
              On https://www.zabbix.com/download_agents#tab:40LTS you can find precompiled AIX agents 4.0.7 for AIX 6.1, 7.2 (for AIX 7.1 an agent for 6.1 should work).
              The precompiled agents are packaged in simple *.tar.gz files (not RPMs, not AIX installable packages).
              Choose directory for Zabbix agent on AIX.
              Unpack the tar.gz archive there - you will get sbin/zabbix_agentd (the agent) and comand line utilities bin/zabbix_get, bin/zabbix_sender.
              There is an agent configuration file template in /conf/zabbix_agentd.conf. Copy and customize it for your needs.
              To test you can run
              path_to_your_agent/zabbix_agentd -p
              You can start in manually
              path_to_your_agent/zabbix_agentd -c path_to_your_agent_config/zabbix_agentd.conf
              Stop with kill comand.
              Finally you want to start it automatically on AIX boot. Make a start-up script for that (or ask a competent AIX administrator how to do it).
              • storyteller
                storyteller commented
                Beside that i think is a good ideea to make a zabbix user (without shell login) and start zabbix agent from that user, not from root.
            • andris
              Zabbix developer
              • Feb 2012
              • 228
              Thanks! I forgot to mention creating a 'zabbix' user.
