Web monitoring for a page that does not contain text
  • steven@steventharp.com
    • Oct 2019
    I want to write a Web Monitoring test to see a web a page does not contain text. I need this to test the Web Site rights are functional. I know how to write Regex and I see that it can be used but I am not seeing how to monitor for a negative.
    My current required is web.page.regexp[thettp.org,/home,443,"@CDA"]
    CDA is a a Regular Expression .*(CDA).* Set to False
    The error I see is "Step "TEST NDA" [6 of 6] failed: required pattern "web.page.regexp[thettp.org,/home,443,"@CDA"]" was not..
  • Mike2K
    • Oct 2018
    • 60
    If you are just trying to see if you can load the page, why use a regex at all ? Load the page and check if you get an HTTP 200 code...?
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Negation is not easy with POSIX ERE. One way is, if you want to negate the word "test", use: ^([^t]|t[^e]|te[^s]|tes[^t])
        • Oct 2019
        Ok the idea of loading the page and look at codes was a good one I want it to not be there and am seeing a "404 Not Found" so I will use it as the return code. Thanks fixed.
