variable error I can't figure out
  • Yodeli
    • Sep 2014
    Hi all,
    I have been playing with installing zabbix for a while now and have succeeded to get it to run but somehow I can't seem to get past the error I have now:
    Undefined variable: h1t3 [ig.php:15]
    All packages were installed and there are no errors from installing it but still in the web frontend I get this error so it will not let me log on.
    I have a feeling this is a rights issue but I can't find any file called ig.php as well as no hits on search engines.
    Does anyone have an idea what might be wrong here? Is anyone familiar with ig.php or where this error (and the actual variable) might come from?
    Cheers
  • kargh
    • Feb 2014
    • 21
    First, I have no idea. Sorry. I wish I could help (help on these forums is almost non-existent).
    Second, you might want to include the version you installed along with the specifics of the distro you're using.
    That might help you get some response on the issue.
    • Yodeli
      • Sep 2014
      so I noticed...too bad but thanks for your response anyway.
      I installed on an RPi using apt-get on raspbian. does that help?
      the biggest questionmark for me is the ig.php that is mentioned in the error...I can't find that one anywhere...
