Zabbix Email Alerts Issue
  • Mr.Phreak
    • Jun 2016
    Hi All,
    Just having a problem with email alerts, everything was working fine until our ISP had a failure that lost connectivity with the email server and at the same time generated a bunch of alerts.
    Since then, email alerts haven't been sent with the Action being stuck on "In Progress" with x retries left. It's the second time it's happened, and last time was solved by a hardware reset of the zabbix server, but I'd prefer to find out what's causing the issue and only reset the affected service if possible.
    Restarting zabbix-server has no effect. And there are no errors in /var/log/maillog other than restarting postfix
    Cheers,
    Darryn
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Is there something related in zabbix_server.log ?
    • storyteller
      • Oct 2019
      • 23
      Try to reset http server.
