Hi!
I am trying to execute remote a remote command on a MacOS client from Configuration-Actions/Operations-Remote Command.
The Command is:
if ! ps axo pid,command | grep -q "[A]pp Store"; then sudo open -a "App Store"; fi
It check if App Store is running and start it if it isn't. It works in the command line but not when sending it from Zabbix server.
Sending this works:
if ! ps axo pid,command | grep -q [P]ages; then sudo open -a Pages; fi
So the problem seems to be the spaces in the app name, I have tried escaping the Quotes, ", but that doesn't work either.
Any suggestions welcome.
The Command is:
Sending this works:
